Daytime Running Lights Addition
OldNavy
Lansdale, Pennsylvania
2019 Wrangler Unlimited Sport JL
As a new Jeep owner, we have a 2019 Wrangler Unlimited Sport (JL). But we would like to add daytime running lights in the form of moon rings around the headlights, plus the appropriate turn signals and/or fog light changes. However, we do not want to go with the cost of a dealer installation, even though I understand that a software change might also be necessary. Can you advise as to required details and where to search?
HK1s
Canada, Montréal, QC
23 2dr sport 3.6etorq AT
diode dynamics and oracle halos you can install on or inside the headlight.
you just tap power from the fuse box, if there is no factory drl you can stop right here.
if you want a switch you can do with extra wires.
for turn signals you can tap the turn signal from the fender.
to program the computers to change factory DLR settings, there is jscan.
instruction are all available from the manufacturers.
sailscall
Buffalo, NY
2021 2dr Sport 6MT
If you want the halos to blink as well as act as a DRL, search Oracle bi led swichbacks in this forum as well as the gladiator forum. Lot of great info. I like mine. Oracle provides the correct splitter wiring harness and resistors. No programming and no vampire clips. Look up 7443ck led bulbs for your Sport fenders. I bought Lasfit. They looked the same as the Oracles which were more.
