Dash speaker wiring check
Red19
Kevin
Connecticut
2019 JLU Sport S
I’m looking to swap my dash speakers with Kicker 47KSC3504. I thought it’d be a quick connect with metra adapters but the speakers came with crossovers which I’m unfamiliar with. I’m assuming I go three wires of the crossover on the speaker and then cut off the red pieces and splice the positive and negative onto the metra connection to the Jeep? A few pics below. Thanks!
Jeep Wrangler JL Dash speaker wiring check IMG_3886
Jeep Wrangler JL Dash speaker wiring check IMG_3893
Jeep Wrangler JL Dash speaker wiring check IMG_3894
Jeep Wrangler JL Dash speaker wiring check IMG_3887
mrjakecyrus
Jake
Minnesota
2019 Black Sahara
Correct. That’s what I had to do with my kicker speakers and it worked.
Red19
Red19
Kevin
Connecticut
2019 JLU Sport S
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
The speaker connectors in the Jeep base system wiring harness are wired backwards. It's a good idea to buy one of the cheap Amazon speaker polarity/phase detectors to verify if your speakers are in phase.
Red19
Red19
Kevin
Connecticut
2019 JLU Sport S
Great to know. Thanks for the heads up.
SargeDiesel
Michael
Birmingham, AL
JTRD
There is a free app so you can use your cell phone. Might save you some $$
Red19
Red19
Kevin
Connecticut
2019 JLU Sport S
Good heads up for anyone else. I got the $12 Amazon special coming tomorrow. Thanks!
Red19
Red19
Kevin
Connecticut
2019 JLU Sport S
I got the polarity tester today and wired the speakers after work. @Jebiruph was right and my system was wired backward from the factory. Easy enough fix with the tester and sounds better than stock. Thanks all for the tips.
Jeep Wrangler JL Dash speaker wiring check IMG_3902
tkept149
MI
'24 Sahara 4xe
How did you test and fix?
Red19
Red19
Kevin
Connecticut
2019 JLU Sport S
Bought a polarity tester, though there are apps apparently too- https://www.amazon.com/dp/B07MQ55QHL
Then used this video via Carplay-
If your speakers flash three greens then a red, wire your new ones the same. If they flash three reds then a green, do the opposite. It’s as easy as switching the negative and positive wire to the metra connector.
Jebiruph
Jerry
Iowa
Did you test all the speakers? It doesn't matter if the speaker is wired positive or negative, you want all speakers wired the same. All positive or all negative. If you are retaining any factory speakers, you want the new speakers wired negatively to match.
Red19
Red19
Kevin
Connecticut
2019 JLU Sport S
Yep, I used the polarity tester on the roll bar speakers (use the fade to get these) and then the kick panel ones and they were all 3 negative and 1 positive. I did a loose twist of the metra and the new dash speaker to make sure it was the same 3-/1+. I also wanted to check how well the tester worked so I swapped the loose twists and got 3+/1- so it was working. I swapped back and then crimped and installed for good.
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
The speakers being wired out of phase (technically not backwards) may not be an "error" on the factory part. In some cases, the audio company doing the design work when it comes to making it sound good in the car may make them out of phase at the speaker to make them be in phase when the sound reaches the ear. Technically, you want all speakers to be in phase when the sound reaches the listener.
Red19
Red19
Kevin
Connecticut
2019 JLU Sport S
Good call out. I’m definitely not an expert on this so may have used the wrong terminology. If I was to use the factory color coding diagram I had been referring to my install would have been out of phase for my Jeep. The tester made it easy to confirm that I should switch it.
lashlee
Knoxville, TN
You should make it sound the best at your ear. It may be out of phase at the speaker or it might be in phase. You confirmed the speaker is in phase at the grill, not at your ear.
