Sting_NC_USA
- Michael
- Mar 25, 2018
- Greensboro, NC
- 2018 Jeep Wrangler JL Unlimited Rubicon
- Build Thread
- Link
- Vehicle Showcase
- 1
You have to pop the side dash panels on the driver and passenger side (body clips only, no screws). Under those panels are a number of screws. You should be able to see which ones hold the front dash in place, as they'll be the ones tied to the dash itself, which is most of them. Remove those screws. There's also a screw that's recessed in that area, and it (if memory serves) connects to the kick panel enclosure. It's very difficult to see, and don't tell anyone, but I never replaced that one when I put my stuff back together. Shhhhhhh!Can someone let me know how to access the lower dash speakers? Thanks for the help.
Next, remove the glove compartment door (there's a "latch" inside and at the top of the compartment door that you use to release the door), and also remove the panel underneath the steering column (body clips only, no screws - pull it straight out). This will reveal more screws holding the dash in place, and you'll need to remove those.
There are two additional fasteners holding the speaker enclosures in place, and you may have to use a small ratchet with an extension to remove them (I think the screws are the same size as the ones you've been removing. Since we're not removing the entire dash, you'll need to engage your contortion skills to maneuver a tool in there to remove the top fasteners holding each of the enclosures in. The bottom one on each side is easy, it's the top one on each side that is a pain. It's kinda' tough, but can be done with patience.
Next, disconnect the molex-type plugs connected to the speaker enclosures. Your driver-side speaker enclosure also has something called a "Gateway" attached to the back of it. You'll want to disconnect those plugs as well. When you put everything back together, and your radio doesn't work, it's probably because you forgot to plug the gateway's cables back in. That was 30 minutes of troubleshooting time I could have saved had I remembered that step.
From there, you should be able to pull the dash section on each side of your Jeep out enough to "pivot" the speaker enclosure out. Don't pull to hard, as you don't want to crease your panels. There's a bit of an art to it, but it's fairly straight-forward once you're in there. If you've missed any screws, you'll know right away. Just be patient. Nothing has to be forced in order to be removed and/or replaced.
I'm confident I've missed something, but reach out if you run into anything other than what I've described, or if I can further clarify anything above.
