Cooper AT 3 odd sizing available
Altitude2020
Canada
2020 Jeep Wrangler JLU Altitude
I have a Sahara JLU 255 70 18's. I can only get these 1 tire size 265 70 18 No off roading, however I am towing a Travel Trailer 10 times a year. Roughly 1,000km in total. What are you thoughts. Cooper AT 3 will be the replacement. Three peak mountain. I dont want to change tires every season. These are 100 dollars less per tire then any other brand k02, wildpeak and Duratrak.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
You wont even notice a difference. The very slight size increase wont have any effect at all.
Altitude2020
Altitude2020
Canada
Thanks, I wanted 275 70 18 but they are not 3 peaks. I'm going for good and cheap. They are $250 each Canadian. Probably better than my stock tires.
azwjowner
Phoenix
I ran the passenger-rated AT3 4S (and its predecessor, the AT3) on my WJ for seven years in the desert southwest including many miles offroad with zero punctures. Great on-road manners too; very quiet and good handling. I would highly recommend them.
Altitude2020
Altitude2020
Canada
I am hoping that they are better than the stock tire. I will be towing 3200 lbs. The XLT would be to stiff of a tire.
Cutterone
NH
2025 Willys 4dr 2L Firecracker
I have a 2021 Sahara 6sp, run 275-65-18 Toyo OC AT3 Load C. Great tire, 3Peak rated, also kicked ass on a few jamborees. I'm going to 275-70-18 next, a true 33 at 33.3", found them in General ATX, they are a SL load, only 46lbs. Unfortunately 18" wheels severely limit tire choice since most at load E which I want to avoid...
Altitude2020
Altitude2020
Canada
I can only find the Cooper XLT in the 275 70 18. I want to avoid the XLT version for the same reason. So I think I can only get 265 70 18 Coopers here. I just want a better tire for snow and towing our travel trailer. The Coopers have really great reviews and are $250 Canadian each compared to $350 each for the others.
Cutterone
NH
Well research the Generals first see where the price and availability is at...
