Clock Setting
RitaB
Rita
LaPorte IN
2025 Wrangler Rubicon
My clock switches every time I drive into a different time zone, which sometimes is numerous times a day.
I have it turned off to sync with the gps and on my phone.
I prefer it to stay in my home time zone so this makes me crazy!
Any suggestions?
yokramer
A Land of Petty Tyrants
Snark Incarnate
If it is synced to your phone, which also is likely switching time zones there isnt likely anything you can do. Your best bet is probably going into the settings and just locking it to your home timezone.
RitaB
Rita
LaPorte IN
My phone does not switch time zones, that is turned off also. My dealership has a call into Jeep, but they haven’t bothered calling back. I’ve had this Jeep for a week, brand new 2025.
ForgottenTaco
CT
‘23 Sarge Green JLU Willys
There’s a setting in my ‘23 to change the clock settings. Maybe play around with the settings, check your owners manual or maybe ask in google. 🤷‍♂️
RitaB
Rita
LaPorte IN
I have done all of the above my phone and my clock are both set to not change which has not stopped it from changing. Even the Jeep dealership contacted Jeep and they told them that that’s just the way it is. That is an unacceptable answer to me.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
If it has an option on the menu of the radio itself to take it off of GPS time, do so. You are in an area that is at the edge of the central time zone, and the only tiny part of northern Indiana that isn't in eastern time. Simply driving a few miles could cause it to move forward one hour, based on where the GPS believes you are.
Terrymo
Terry
2023 JLURXR 3.6 ET
I’m pretty sure you said you have done all this but just in case. With the GPS sync time disabled and no phone in the vehicle I would be curious to see what happens. It would at least eliminate one thing for the dealership to blame the issue on.
Jeep Wrangler JL Clock Setting IMG_4112
Wbino
NJ
I would think knowing what time it is at the location you're currently at would be a good thing.
A watch set to your home time on your wrist would solve that issue.
Overkill
Michael
Paris, IL
Rubicon392.com
2024 392;2002 TJ Sport;2005 GMC 2500HD;1969 Camaro (x2);1974 Chevy Cheyenne K20
Information Technology
I know I fought this issue for a while on my 2024 Uconnect 5 and gave up and just use wireless Android Auto so the clock displayed is the one from my phone. I live in central and work in eastern and like you, I like my clock to stay on one time so I don't have any confusion. I think it is a bug in Uconnect 5. I don't remember it being an issue in the 2018, 2019, or 2023 Uconnect 4 Wranglers I had.
The Last Cowboy
San Antonio, TX
When I cross from mountain to central and back, it can take several miles for the time on my phone to change.
My Jeep has a base radio, and no SXM, so it never changes, unless I change it.
RitaB
Rita
LaPorte IN
I just want it to stop changing!!
jadmt
jeff
montana
I got mine to stop changing as I too go back and forth between time zones sometimes multiple times in a day and could care less what time it is other than at home...mine is a 2024 with xm radio etc...I will go see if I can find out what box I checked...I couldn't see anything so not sure what I did.
RitaB
Rita
LaPorte IN
Thank you I’m wondering if it’s not a needed update because I had issues today with the GPS also🤦‍♀️
