Check coolant with Jeep running?
Linda z.
Linda
New York
2021 Jeep Sahara 2L Turbo
Me again. Checked coolant level this morning didn't register on dipstick so I added the correct coolant, about a pint. Is it supposed to be checked with the Jeep running? Thank you.
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
Should be above MIN with engine cool. If you sucked in air you may need to check it through several hot/cold cycles as it works its way out.
NWJeepr
Twin Peaks
2025 Wrangler 2-door
No, do not check when it is running. If the engine is cold, off, the level should register above MIN.
If you do a warm check, it should be above min but below MAX. Never open a hot radiator or overflow tank. Read the owner's manual if you need clarification on how to check the level.
My 2.0 was reading below min shortly after I purchased it new. I added enough to bring it up to max when the engine was cold. In 2,000 miles of driving since then the level hasn't changed so I'm thinking there's air from the factory or it's just under-filled.
Linda z.
Linda
New York
Thanks so much.
tk1700
Tom
New Mexico
2021 JLUR, 2016 Tundra, 2025 Hyundai Palisade
Do you have an owners manual?
tk1700
Tom
New Mexico
Page 408 of 2021 owners manual for the 2.0 turbo:
408 SERVICING AND MAINTENANCE
With the engine OFF and cold, the level of the
engine coolant should be within the OK range between the ADD and FULL range on the dipstick.
  1. Remove the cap with level dipstick from the engine coolant bottle.
  2. Clean off the coolant from the dipstick.
  3. Rest the cap on the opening of the coolant bottle without tightening the cap.
  4. Remove the cap with dipstick and check the coolant level on the dipstick.
