CAN Bus fault codes - need help
JEE
Nova Scotia
Jeep Rubicon
Hi,
Is someone out there that knows what is wrong - Help needed !
2019 JL 2.0L engine
see screen shots.
Jeep Wrangler JL CAN Bus fault codes - need help CAN 1
Jennitran
Jennifer
Mazda
Hi,
2019 JL 2.0L engine Visit Autoguysland to review and find car dignostic tool that you may concern.
see screen shots.
U codes are problems on the CAN - controller area network serial data bus. You check if there is a bad module or a wiring problem or not.
JEE
Nova Scotia
Jeep Rubicon
No, was hoping for some solution from you guys :)
This must be some water integration to a plug - I saw this after I cleaned the car ! I took the car in to my workshop and had it inside for a week to see if the moisture would evaporate. Still the same problem.
thanks for your reply
Nilan
Nicolas
France
Wrangler JLUR 2.0 IT Punk'n Metallic
Hi,
2019 JL 2.0L engine
see screen shots.
Hi,
I have the same kind of problem with the CAN bus on my JLUR 2.0L.
The gateway is in red like yours and several modules are faulty.
The problem appeared when updating the option code following the replacement of the steering box with the new model and the addition of the hardtop harness.
My Jeep has been stuck at the dealership for two months now.
They replaced two faulty modules without any improvement.
They no longer know what to do and tell me that it is undoubtedly the bypass gateway of my Superchips FLashcal box that caused the update to fail.
What is strange is that when we reconnect the gateway bypass, there are fewer errors but the steering pump cuts off as soon as we turn the steering wheel.
And when we put it back as it was original, there are a lot of errors and the automatic gearbox doesn't work at all.
Have you found a solution to your problem?
I hope your solution will help me solve my problem.
lowflyer
Sven
Belgium
Jeep JLU Rubicon
Hi,
I admit I forgot to unmarry it and reconnect the cables to the firewall as it left the factory.
Hello,
@Superchips JL @Superchips_Mrktg
Can you help my friend please?
We really need some help here...
Thanks, Sven
lowflyer
Sven
Belgium
Jeep JLU Rubicon
Hi @JEE,
some help would come in handy, what was your solution?
Thanks, Sven
