lowmpg
- Ryan
- Apr 2, 2021
- Kent Island, Maryland
- 2021 Rubicon, 2025 Ram Limited
The battery wire gives the camera constant power, the ACC wire tells it to draw power when the ignition is running. The battery hot allows the device to run when the vehicle is 'off'. You can wire the ACC/battery together on one AUX switch. Then through the Jeep you can set the button to always use the battery.
I currently have my dashcam wired to AUX4 and have it run from the ignition.
AUX setting for battery or ignition:
