Am I the only one who doesn't know what "The Big" 3 are?has anyone done the big 3 upgrade to their jeeps yet? if so was the process the same as other cars? or completely different cause of the second battery?
NopeAm I the only one who doesn't know what "The Big" 3 are?
Come on man...you know the big 3 for audio and such. It's Led Zeppelin, The Who and Jimi Hendrix.Glad we cleared that up.
Well, you got two right. ;-) The Who? Nope!Come on man...you know the big 3 for audio and such. It's Led Zeppelin, The Who and Jimi Hendrix.![]()
Wrong...our marital counselor says the big 3 is in-laws, money and sex. No couple has all 3 figured out!The Big Three is larger gauge and/or higher quality wiring in 3 key areas to improve car audio output and quality: the battery negative to chassis ground cable, the engine block to chassis ground wire(s), and the alternator positive to battery positive cable.
The simple answer is that it can almost always improve the entire electrical system in any vehicle, including the sound system. I don’t have a Jeep to examine. But the auxiliary battery shouldn’t create a problem. I would think that for it to be effective though you also might need to enhance the wiring connecting the two batteries.
I appreciate your reply, I'm not sure if they're trolling or truely unaware of what the big 3 upgrade is. Im thinking of swapping terminals to a beefier one to accept multiple 1/0g wires and I also plan on keeping the factory wires attached while "enhancing" the flow.The Big Three is larger gauge and/or higher quality wiring in 3 key areas to improve car audio output and quality: the battery negative to chassis ground cable, the engine block to chassis ground wire(s), and the alternator positive to battery positive cable.
I think your OP would fit the definition of trolling more than our pithy responses.I appreciate your reply, I'm not sure if they're trolling or truely unaware of what the big 3 upgrade is. Im thinking of swapping terminals to a beefier one to accept multiple 1/0g wires and I also plan on keeping the factory wires attached while "enhancing" the flow.
