Soapy
Idaho
2025 Wrangler Rubicon X 2 door
A quick update on this Wolfbox compressor. Seems to be built heavy duty, not a light weight. it has 7 foot jumper cable built in leads and a heavy quick couple hose about 1 foot long coming out of the box. cleanable inlet filters. Comes with a long air hose with quick couplers and a short 1 foot lead with a quick coupler and screw on valve stem lead. You will want to grab a quick connect air valve adaptor for the valve stem since no one I know screws them onto each valve stem. dimensions are about 5 inches thick by 10 inches high and 10 inches long. It does come with a carry bag that will hold everything. My only issue so far is the bag. It is pretty light canvas and comes with no padding and no wolfbox name on it. FOr a heavy compressor it should have a padded bag to protect it and a name on the bag so it is easily identifiable. I cannot comment on it performance yet but will in the future when I use it.
gek
Code Monkey
For reference, Arb brushless took me 3mins 26 seconds to fill up all 4 37s at once from 10 to 30 psi
Waldeck
Bob
New Jersey
fadingbarns.com
2025 Jeep Wrangler Rubicon 2door
For those of us not accustomed to thinking in the Celsius scale:
25C = 77F
40C = 104F
The only place they are the same is -40 and I've been there, don't take a piss.
Reaper-1
Jose
Las Vegas
2024 jlu rubicon
Attention off-road enthusiasts and overlanders! We’re thrilled to announce the launch of our all-new Wolfbox HyperFlow 60D Air Compressor—a game-changer for your air inflation needs. Designed for durability, efficiency, and high performance, the HyperFlow 60D is built to handle even the toughest challenges. Here's why this powerhouse should be your go-to air compressor.
Purchase on Wolfbox site!
Purchase on Amazon!
Why Choose Wolfbox HyperFloew 60D Air Compressor?
  • 100% Duty Cycle: Can operate continuously for 60+ minutes under full load in 77F environments without stopping.
  • 104F High Heat Resistance: Performs exceptionally even in hot climates, working non-stop for 40 minutes.
  • Innovative Cooling: Dual-side active fan intake with an open heat dissipation design keeps the system cool under pressure.
  • Extreme Durability: Built for continuous high-load operations, with a core life of up to 80–100 hours.
  • High Output Performance: 5 CFM @ 40 PSI, ensuring quick and powerful inflation.
  • Perfect for Large Tires: Designed for 35–40” tires—inflate a 37-inch off-road tire from 10–40 PSI in just 3 minutes!
  • Auto Shut-Off: Set your desired tire pressure and let the compressor do the rest. It stops automatically with only ±2 PSI variance.
  • Multi-Wheel Inflation (Optional Accessory): With a high-pressure air source splitting into four independent airways controlled by solenoid valves, you can perform single-wheel, multi-wheel, or four-wheel simultaneous inflation. (Requires additional 4-Tire Inflation & Deflation System.)
Performance at Its Peak:
  • 120L/min flow rate at 40 PSI, ideal for fast and efficient inflation in every adventure.
Special Launch Discount:
  • Regular Price: $369.99
  • Introductory Price: $329.99 (Limited time only!)
Purchase on Amazon!
Looking for an On-Board Air Compressor?
If you’re into onboard setups, check out the Wolfbox HyperFlow X for the ultimate convenience.
Don’t miss out on this incredible deal—gear up with the Wolfbox HyperFlow 60D and conquer the trails without worry!
Available Now: Get yours today and experience inflation like never before!
Purchase on Amazon!
I’ll stick to power tanks…
