Back Up Camera wire smashed
traviswalker007
Tony T Walker
Phoenix, AZ
2018 JLU Rubicon
Does anybody know how to fix or splice the back up camera wire? i tried soldering the center wire under the plastic sheathing but did not work. Jeep does not offer the pigtail replacement yet and all the sell is the entire tire carrier unit with everything. I pulled the camera off, and cut the other end of pig tail off were it connects to the tailgate wire, was thinking of taking it to a audio video store to see if they could splice it. I cannot find the type of wire that jeep uses or the connection. Has anybody done this of can give me an idea?
bwilliam79
Brandon
Dallas, TX
2016 F-150, 2018 JLUR
Believe it or not, I made this exact same mistake when I put on a tire mount relocation bracket. I called the local Jeep dealership and they said they could get the wire for me, but it was over $100 and wouldn't be available for a couple of months. I ended up splicing my wire back together. Unfortunately, I only took a before picture, but this is what I started with.
Jeep Wrangler JL Back Up Camera wire smashed upload_2018-10-22_10-51-13
I took a small piece of shrink tube and placed it over the white wire and a large piece of shrink tube over the outer wire (you can actually see the larger shrink tube on the left, right at the edge of my desk), then soldered the break back together. Moved the smaller shrink tube over the solder joint and put a heat gun to it to set it in place. After that, I just pushed the wire mesh back together as best I could, then moved the larger shrink tube over that portion and put a heat gun to it. It has worked like a charm ever since.
It's a simple RCA style cable as best I could tell, but fortunately I was able to salvage mine.
bwilliam79
Brandon
Dallas, TX
Correction. I looked up my chat history with the dealership and it was $76 for the cable. I broke mine in mid-August and at the time, he said I'd be lucky to have it by October.
traviswalker007
traviswalker007
Tony T Walker
Phoenix, AZ
2018 JLU Rubicon
First off thank you for responding!! nice to see someone else did the same thing LOL. I did try to splice it but the camera was still blue screen when i plugged it back in? do i need to reset the battery or did i do it wrong?? i ended up cutting the cable to short so im looking for similiar cable to slice into and make it longer, any ideas??
bwilliam79
Brandon
Dallas, TX
I didn't have to reset the battery. If you're still getting a blue screen, I'd say the splice is bad at a minimum. You could always test the camera by redoing the splice and just hooking the camera up (without installing) to make sure it even works. Assuming the camera is good, I'd think you are on the right path by looking for a thin RCA style cable to remake/replace the bad section to get the length you need.
firedog561
Jason
Eastern Shore of MD
2018 JL Moab
do you know what the part number for the camera wire is?
bwilliam79
Brandon
Dallas, TX
Unfortunately, I don't. I just texted a picture of the part to the dealer and they were able to look it up to give me a cost. Sorry.
bwilliam79
Brandon
Dallas, TX
Yes, in theory you should be able to solder in your own extension using another RCA cable. I just repaired mine vs extending, but the work required is the same. As long as you're careful and do a good job with insulating the inner cable from the outer mesh, you should be good. Heat shrink tubing is your friend for this work. :) Good luck!
AmericanMule
Josiah
Everywhere but home
JLUR Bright White 3.6L
Traveler
Also this is an option depending on where it was smashed. Sometimes the challenge is a little more enjoyable. I believe this is the only one I could track down. I plan on adding a tire carrier so this should do the trick.
https://www.amazon.com/EAG-2018-201...s+jl&qid=1551795961&s=gateway&sr=8-4-fkmrnullhttps://www.amazon.com/EAG-2018-201...s+jl&qid=1551795961&s=gateway&sr=8-4-fkmrnull
https://www.amazon.com/EAG-2018-201...ra+harness&qid=1551728782&s=automotive&sr=1-7
cball508
2022 Wrangler 392
I did the same. Got the wire/harness in today. This part number is a replacement for backup camera and third brake light wire. It comes with harness, grommet for the door, and wrapped together like the factory one. Hope this helps!
Jeep Wrangler JL Back Up Camera wire smashed 20190617_202546
Krondor
Here, but soon there
2018 Punk'n Jeep Wrangler JLR
AmericanMule
Josiah
Everywhere but home
Traveler
