Alignments
ResqFE
Ron
Ensenada Baja MX
2018 JL Unlimited
I am finding the need to do a alignment after most moderate offroading. Will aftermarket steering parts keep the steering alignment better?
jdubya421
Jakob
Greensboro, NC
2020 Rubicon 2-Door MT V6
Are you making sure to re-torque all the nuts and bolts after offroading?
ResqFE
ResqFE
Ron
Ensenada Baja MX
2018 JL Unlimited
Not typically after each run. Do go through periidically without noticing anything loose.
jdubya421
Jakob
Greensboro, NC
I do it basically every time. When you say steering alignment what do you mean? That your steering wheel is off center? Or something else?
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
what is making you think you need an alignment? There is not much that you can adjust on factory suspension and steering, just the steering wheel center and the toe. It is possible to throw off your alignment on the trail most often ive seen is a bent track bar or some other linkage got bent or broken.
Also common is mud/ice build up on the wheels or driveshaft that causes them to get out of balance which causes bad vibrations and other issues while driving
ResqFE
ResqFE
Ron
Ensenada Baja MX
2018 JL Unlimited
With a good alignment, no wobble... wobble is worst after going out. No mud.
Sheepjeep
Ma
Check that all of your joints are tight
