Alignment ratios- jlur 2020
Hasan mahajna
Hasan
Israel
Wrangler unlimited rubicon 4D 2020 2L turbo
Hi
I did alignment today and the ratios seems like this , can you see and tell if its ok ?
It doesnt have to be the same at both sides ?
Thanks
Jeep Wrangler JL Alignment ratios- jlur 2020 IMG_7419
LazyJL
Larry
2020 Rubicon, 2001 built XJ
Retired fabricator and mechanic
With the lack of responses, I'm guessing few here can read Hebrew technical jargon.
A translation would be helpful.
Hasan mahajna
Hasan mahajna
Hasan
Israel
The position of the tires is the same - and the angle is the same at the diameter so , i dont know why no one comments , maybe later they will “ i hope “
Thanks for the response
jadmt
jeff
montana
the camber looks good as does the thrust angle. I am not sure why they did not measure castor as that is an important measurement. If you are wondering why they are not the same numbers side to side that is completely normal...
