Adding an ACC power distribution block in the engine bay
tengg2001
JLUR
Hi there,
I'm thinking to add a box near the battery to distribute power. Did some search in the forum, and it seems many recommendations for the Blue Sea fuse box:
https://www.amazon.com/Blue-Sea-Systems-Blade-Block/dp/B001P6FTHC
I have a few questions with regarding to the wiring:
1. I want it only powered on with ACC, so my idea is to have a solenoid or relay from ACC, to switch on the power line from battery. What's the best way to get a voltage tap from ACC? Previously I use fuse box F43/F45, but it's an awkward location and the fusetap doesn't work well at that location.
2. How do you mount the Blue Sea fuse box? I've seen the mounting bracket for $40 or $90, which is just a piece of metal with some holes.. Any more reasonable way to get it done?
jludave
The Isle of Long
IT Manager
