About to install a full steering setup, is Loctite required?
James Cole
NY
JL
Hello Guys...
I am about to install:
-Trackbar
-Draglink
-Tie Rod
- Steering Stabilizer (Falcon 2.2 JK)
-Lower Control Arms
Is Loctite needed in any of these and what colour should I use?
Thanks a bunch and will report improvements if there are any.
JC
MarkY3130
Denver
2019 JLUR
Hello Guys...
-Trackbar
-Draglink
-Tie Rod
-Lower Control Arms
JC
If you can specify what product you are using it will help. For example, on all the adjuster sleeves of the steersmarts stuff I used anti-sieze instead of locktite. I didn’t use locktite at all on the ends but did torque them down correctly.
Hope you own a pickle fork, without it I would have had a bad time separating the joint at the pitman arm. That sucker was tough even with the correct tool!
