33x12.5x20 with -25 offset?
JLPete
Virginia
2022 Sahara
Hi All,
I searched the forums before I posted and couldn’t find anything so apologies if this has been covered.
Will 33x12.5 on a 20x10 -25offset rub on a stock 22’ Sahara 4xe?
MonopoliJLUR
Gabriel
Ontario, Canada
2021 Jeep Wrangler unlimited rubicon
If you mean for on road driving? Then you will be fine
JLPete
Virginia
2022 Sahara
Thanks for the quick replies -
I understand the stance and I personally like that look. Only off-road this Jeep sees is the beach, so no big trail flexing, etc.
I don’t want to sacrifice any drive ability so would these rub on bumps at highway speeds?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Jtclayton612
Memphis, Tn
2020 JLU Sport S
There should be no rubbing on road with they offset.
blnewt
New Mexico
Just ask @cosine he knows!
Won't rub but will have an effect on your scrub radius, if you like the look then that's your call. I wouldn't go that aggressive as it will decrease your steering response. This is something you can get used to but you are going quite outside what the steering geometry was engineered for.
JLPete
Virginia
2022 Sahara
Appreciate all the responses here. I may just do a rough country leveling kit.
Any advice on brand?
BEACHED WHALE
SLC
JLR
Hi All,
dont do it!!! you will suffer big performance loss
GATORB8
CLT NC
BEACHED WHALE
SLC
JLR
I think he’ll be fine with the 1” difference in diameter. 470 ftlbs and all.
-25 offset, 12.5 tires for just looks.. I would never but Im just warning you that the jeeps street performance will suffer a lot. in a month it will be one of those used jeeps on the lot with ugly aftermarket tires. Just think about. Plus if you do a lift, you'll want 35s.
