3 wire swtich model red black yellow
Hd088
Hassan
Brooklyn ny
Jeep wrangler JLU 2021
I have recently installed offroad lights on my jeep im looking to do wire where can I buy swtich with red black yellow option has day running
Jeep Wrangler JL 3 wire swtich model red black yellow Snapchat-1299030542
Terrymo
Terry
2023 JLURXR 3.6 ET
Do you want an illuminated 12 volt 3 pin “on off“ rocker switch, or a 12 volt 3 pin “on off on ” switch to alternate between powering two devices on one switch?
Omen
Wisconsin
2022 JL Willys 2.0
IT Manager
Light schematics/instructions would be helpful. Some systems use a momentary on in their circuit. We would need to know what lights you are working with.
Hd088
Hd088
Hassan
Brooklyn ny
I want on and off on
Some amazon knock off look at the pics
Omen
Wisconsin
2022 JL Willys 2.0
IT Manager
I can't really tell what they are, so... 🤷‍♂️
Good luck in the search for your answer.
Hd088
Hd088
Hassan
Brooklyn ny
If u can help me get 3 pin on off on swtich would b perfect
https://ebay.us/m/Y8dkMS
Check out link and let me know if u can help thank u
Terrymo
Terry
2023 JLURXR 3.6 ET
Do you want to control two devices from one switch so they are on separately? if so you want a 12 volt 3 prong on-off-on rocker switch.. In the center position nothing receives power.
This isn’t intended to be a wiring diagram, or advice you should follow, just a basic but incomplete concept. With the toggle (or rocker) moved to the left hand side the right prong receives power. If it’s moved to the right side the left prong receives power. Move the toggle (or rocker) to the center position and both sides are off.
You will need to provide a lot more specific information for anyone to give advice. I don’t have the knowledge to recommend specific switches, relays, or wiring diagrams based on what you’re saying. Nobody wants your Jeep to burn down because of a miscommunication on either side. Any reputable car stereo shop could safely do this for you at a reasonable cost.
Jeep Wrangler JL 3 wire swtich model red black yellow IMG_4123
Jeep Wrangler JL 3 wire swtich model red black yellow IMG_4124
Hd088
Hd088
Hassan
Brooklyn ny
Thanks man I appreciate it i think i will just go with red and black wire
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
You need an “on-off-on” switch that will mount wherever it is you’re planning to mount it. Depending on how you want the lights to work, and the current they consume, you may need relays and diode as well.
You really have not provided enough specifics for anyone to give you an exact answer.
Terrymo
Terry
2023 JLURXR 3.6 ET
Those pics I posted are just to try to explain a basic on-off-on switch, not a wiring diagram you should follow. If you’re not 110% sure what you're doing there is no shame in having someone else do the job.
