UDUBJL
I have been reading and searching threads for over a week. It makes my head swirl and I have not found an exact answer. I am wanting to put 315 70 17 Patgonia MT tires on my stock rims with no lift. I do not have the metal bumpers. Will this be an issue? If there is an issue with fitment where will the issue be? I will eventually be doing a 2 or 2.5" lift on but probably not until next Spring. And last portion of the questions is if the issue with fitment is the stock rims what width rim should I get and with what backspacing? I do not want them to stick out very far if at all. Thanks for any help you can provide. I should also add that I will be going offroad with it. No serious rock crawling but will go off road in the mountains and use the sway bar disco's.
