2018 Wrangler JL Coolant issue
Jerseydevil65
Drew
2018 Wrangler JL
I noticed the other day that my engine fan sounded very loud as I was driving. I also noticed that the temp gauge shot up to the top twice and shot back down to normal a few times when driving. I checked under the hood and noticed I was completely out of coolant. I filled it with 50/50 and today I took a short drive and everything seemed fine however, when I checked the coolant level when I got back home, it was completely empty again. I did not see any leaks or find any coolant on the ground. Any explanation?
ScotM
Scot
Southern California
2022 Jeep Willy's JL 2 Door
Do you check by the water pump and under the coolant tank? There is a big problem somewhere.
Jerseydevil65
Drew
2018 Wrangler JL
Have not checked, will do that today. Just surprising that all the coolant is gone and not on the ground.
_olllllllo_
William
The Wild Wild West in AZ
2019 Hellayella JLU Rubicon 6-speed
I would check your oil to see if it looks like a milkshake, which definitely indicates coolant in the oil system.
You can go to O'Reilly's or AutoZone and rent a cooling system pressure test. This could help hear where a leak is coming from. Heater core is a possibility and you would notice it with a sweet smell from the coolant.
ForgottenTaco
CT
‘23 Sarge Green JLU Willys
I changed my oil a couple weeks ago. Didn’t see anything unusual with the oil but decided to check the coolant anyways. The stick was bone dry. I ended up adding about a quart before it finally registered on the stick. I drove it around and checked it again the next day. Had to add about another half quart. Drove it around again and checked the following day and it was normal.
2.0 turbo 4 banger
