2 door Hard top Configurations
JakeM
Jake
Austin, TX
Ford F150,VW Atlas Cross Sport,24’ Wrangler Sport
New wrangler owner here- was wondering if anyone has removed the hard top but kept the doors and freedom panels on- I have seen pictures of the soft top in a safari mode. but never seen a 2 door just with doors and freedom panels- thanks for any input, pictures, pros/cons.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
I've seen that done. It won't give you the same look as safari mode though. I've also seen no doors, roof panels on.
BXFXJeep
Toronto, ON
2021 4xe Sahara
The only con really is the rear latches can rattle since the main section is not there to latch.
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
I’ve run hardtop off / freedom panels on / doors off no issues whatsoever. Just make sure everything is good and tight and you’ll be good to go ?
GRAK
Out West
JL Rubi, Corvette
I did that for the first time when I had to go pick up a soft top; I wasn’t sure if it would fit inside with the hard top on so I took that off then it started raining just as I was about to leave.. so I drove with the panels on with back open while on the freeway, and was fine yeah.
Jeep Wrangler JL 2 door Hard top Configurations 1707679615849
JakeM
JakeM
Jake
Austin, TX
Good to hear, thanks for the pic. Being in Texas I plan to run a open configuration most of the time.
wuzwiz
NE Georgia
2023 JL 2 Door
I drive a 2 door. I've done it with freedom panels, doors on, no back seat and a windstopper. Kind of a really short p/u. Worked pretty well.
