Adventure Lab (Team)
Peak Sponsor (Level 2)
Utah
AmericanAdventureLab.com
JLU 392, JLU 4XE, JT, JK, JKU, LJ
Chief Thinkerupper
Welcome
American Adventure Lab
www.AmericanAdventureLab.com
Phone: 435-414-0615 | Email: [email protected] | Instagram: @americanadventurelab
https://americanadventurelab.com/product/jeep-jl-mass-cargo-shelf/
One of the biggest challenges with the Jeep Wrangler JL is making efficient use of the cargo area without sacrificing accessibility, visibility, or rear-seat functionality.
Traditional drawer systems can be heavy and permanent, while loose gear often ends up stacked on the cargo floor with limited organization.
We wanted a better way to maximize the space already available inside the Jeep.
The American Adventure Lab M.A.S.S. Cargo Shelf creates a strong, adjustable second level of storage in the rear cargo area of the Jeep JLU, allowing you to separate gear, improve organization, and secure cargo for everything from daily use to extended overland travel. Designed around the M.A.S.S. ecosystem, it provides nearly unlimited tie-down options while keeping your cargo area flexible and adaptable.
Features & Benefits:
• Designed specifically for the Jeep Wrangler JLU (4-door)
• Creates a raised storage platform above the cargo floor
• Adjustable height design to accommodate different gear configurations
• Lightweight yet durable 5052 aluminum construction
• Approximate shelf weight: 30 lbs
• Dogbone cutout pattern provides nearly unlimited cargo tie-down options
• Compatible with Mac's Single Stud Tie-Down Rings and strap systems
• Helps organize camping gear, recovery equipment, tools, refrigerators, and storage bins
• Maintains usable storage space underneath the shelf
• Compatible with many M.A.S.S. accessories and cargo management components
• Available with optional MOLLE Bulkhead integration for additional organization
• Designed and manufactured in St. George, Utah, USA
Installation Notes:
• Mounts directly to the factory roll bar structure
• Adjustable mounting positions allow you to tailor storage height to your needs
• Installation requires basic hand tools
• No custom fabrication required
• Works with both hard top and soft top configurations
• Designed for JLU (4-door) applications only at this time
Frequently Asked Questions
Will this fit my Jeep?
The current M.A.S.S. Cargo Shelf is designed specifically for the Jeep Wrangler JLU (4-door). A 2-door version is not currently supported.
How much weight does the shelf weigh?
The shelf weighs approximately 30 lbs while providing a strong and rigid storage platform.
Can I adjust the shelf height?
Yes. The shelf features multiple mounting positions, allowing you to customize the available storage space above and below the platform depending on your gear setup.
Can I mount accessories to the shelf?
Absolutely. The dogbone cutout pattern is designed to work with tie-down rings, straps, bungee systems, and various M.A.S.S. accessories for a highly customizable cargo management solution.
Will it work with a soft top?
Yes. While originally designed around the hard top, the cargo shelf is compatible with soft top Jeeps as well.
Can I still store gear underneath the shelf?
Yes. The adjustable-height design allows you to create substantial storage space underneath the shelf for coolers, refrigerators, storage bins, recovery gear, and other larger items.
If you're looking to maximize cargo capacity, improve organization, and create a more functional storage system inside your Jeep Wrangler JLU, the M.A.S.S. Cargo Shelf is a simple and highly adaptable solution built for daily driving, overlanding, and everything in between.
We're happy to answer any questions about fitment, accessories, installation, or cargo management setups.
Jeep Wrangler JL Turn Your Jeep JLU Cargo Area Into a Fully Modular Storage System | American Adventure Lab M.A.S.S. Cargo Shelf Jeep-JL-Rear-Cargo-Shelf-3.jpg
Jeep Wrangler JL Turn Your Jeep JLU Cargo Area Into a Fully Modular Storage System | American Adventure Lab M.A.S.S. Cargo Shelf Jeep-JL-Rear-Cargo-Shelf.jpg
StJJames
Celestial1488
So, I know with the tray that fits to the cage- you can flip the side mounts to get even more height.
I need like 23 1/2” clearance for my dog crate.
Would it work?
Thanks!
Utah
Chief Thinkerupper
Would it work?
Thanks!
Hey!
From the specs on the JL MASS Cargo Shelf, the maximum clearance from the cargo floor to the bottom of the shelf is about 22". If your crate needs 23.5" of height, it's unfortunately not going to fit underneath the shelf.
You'd be about 1.5" short, even with the shelf set in its highest position unfortunately!
ExpeditionBuilds
Rock Sponsor (Level 1)
Steven
Chicago
www.youtube.com
2020 Wrangler Recon
Photographer/ Content Creator
Great product, I love mine! Solid, rattle free well built storage option. Also the the ability to custom powder coat it is👌🏻
Jeep Wrangler JL Turn Your Jeep JLU Cargo Area Into a Fully Modular Storage System | American Adventure Lab M.A.S.S. Cargo Shelf IMG_5228
Jeep Wrangler JL Turn Your Jeep JLU Cargo Area Into a Fully Modular Storage System | American Adventure Lab M.A.S.S. Cargo Shelf Cargo-1
-Steven
Utah
Chief Thinkerupper
-Steven
Love the setup Steven! Thanks for choosing us!
bemocked
2021 JLU
Hello AL product team!
in terms of storage products/ideas that ought to exist...
I own, and am very happy with, the "NATO Jerry Can Mount" for securing my water jug inside the JL (Universal NATO Jerry Can Mount - American Adventure Lab), nice to know my scepter water jug is not getting tossed around, or toppled over.
What I would really like to see is a similar product sized for an EcoFlow Delta2/3 portable battery-power unit - a metal base that can bolt down to any in-vehicle cargo platform, sized for an EF Delta/Delta2 to snugly sit within, and then either a strap over the top (as is the design for the jerry can equivalent), or maybe holes/slots on the "ends" for strapping down via the EcoFlow unit's handles (trick is then to orient tie downs, so as not to block off access to the plugs on the ends of the unit, so possibly the jerry can's strap-across-the-top solution is best). The battery unit would be a heck of a dangerous projectile in an accident, I awkwardly strap it down now, but covet a more elegant solution like i have for the jerry can.
There are quite a few folks selling 3D printed (plastic, or ABS) brackets for this purpose on Amazon and Etsy, and have been for a couple years - so there does seem to be a market or broader interest for this? Would really like to be able to purchase a robust metal version instead (doesn't seem to exist, yet)??? Is this relatively simple bracket concept something AAL would consider adding to your catalog?
examples:
www.amazon.com/gp/product/B0GXKTW881
www.amazon.com/gp/product/B0F8VDQ8KM
www.etsy.com/listing/4327994280/
www.etsy.com/listing/1528594121/
www.etsy.com/listing/4313681368/
www.etsy.com/listing/4391117809/
Cips
Anthony
Bucks County PA
2021 Wrangler Unlimited Willys
Sales
I love my shelf too, however after about seven months it has developed surface rust. I should have gotten the powdercoated version.
Utah
Chief Thinkerupper
Ordered mine 06/03, just waiting for the email that it has shipped.
Thanks for choosing us, we are working to get everything shipped out as soon as possible!
