Superchips_Mrktg
Jacob
2020 Jeep JL
Jeep Wrangler JL All-new Amp'd 2.0 Throttle Booster with Wireless Switch and App Control! SC_Ampd 2.0_Jeep_1200_x_400 for JL Forum
Introducing the industry's first Throttle Pedal Sensitivity controller with a Wireless Switch! No bulky modules to mount in the cab and no switch wiring to hassle with. Superchips Amp’d 2.0 Throttle Booster is easy to install, delivers immediate improvement with pedal response, and gives you total control of your driving experience. With the all-new Amp’d 2.0 app, our incredibly simple solution and completely customizable pedal maps generate that “seat of the pants power” you can’t find anywhere else.
Decreasing pedal lag expedites your vehicle performance curve to occur sooner and supplies quicker turbocharger spool up. Our five pre-set levels are adjustable on the fly and boost pedal signals instantly. If you’re interested in obtaining even more power levels and options, check out the Amp’d 2.0 app take throttle sensitivity to the next level by creating and saving your on pedal map curves!
Amp'd 2.0 is available for JK, JL, and JT applications. Including 3.8L, 3.6L, 2.0L Turbo and even the 3.0L Diesel!
Superchips_Mrktg
Superchips_Mrktg
Jacob
2020 Jeep JL
TCogs1
Thomas
Somis
cj6
Does this address the speed matching when down shifting? The jl is really bad when downshifting in low range, manual mode, it causes the Jeep to accelerate I.e. 3 to 2nd in low range.
Superchips_Mrktg
Superchips_Mrktg
Jacob
2020 Jeep JL
This module only changes the throttle pedal % signal sent to the PCM, to eliminate the dead pedal feel and improve drivability. The issues you're referring to would need to be addressed in the tuning itself, check out our Flashpaq or TrailDash for help there.
