Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
Sweat Shop Manger, Slum Lord and Break Dancer
Jeep Wrangler JL !!!NEW Product!!! Quake Led FLUSH Taillights are live! Featuring B.A.S.S. Technology - QMT1537 2_Flush Ads
Product VIDEO: Quake LED FLUSH Taillights!
Our newest Jeep Wrangler JK/JL and Jeep Gladiator JT Flush Tail Lights are a category-killer, making all other flush tail options not as interesting anymore! Introducing our new B.A.S.S. (Brake Alert Safety Signal) Technology, that shines a very bright red beam onto the road surface directly behind your vehicle, alerting those behind you to take notice!
This innovative flush mount LED tail light design that wraps tightly around the Jeep for that sleek look! Its low-profile design extends less than half an inch beyond the factory body panels! This design helps lessen the unavoidable damage from trail riding or your neighbor’s spoiled brat who just took off the training wheels!
Even though this flush mount tail light design is extremely low-profile, we have somehow designed the factory blind spot sensors to maintain the original outward positioning! This guarantees full functionality of the system as designed. Other brands are forced to drastically relocate the sensor position, resulting in diminished blind spot sensing capabilities. Not good folks!
Best Jeep Upgrade: These new low-pro Flush Mount Tail Lights are an essential, no-brainer, best bang for the buck Jeep upgrade!
Unbeatably Smart Functions: Start-up Animation, Running Lamp, Brake, Sequential Turn Signal, Standard Turn Signal, Bright Reverse Light and Brake Alert Safety Signal (B.A.S.S.) Technology!
USA: Completely designed, engineered, tested and shipped by the Mad Scientist Jeepers at Quake LED, right here in Denver, Colorado. Produced from the best materials & craftsmanship, guaranteeing head-turns from other Jeep owners!
Three-Phase Sequential Turn Signals: Connect our simplified Lighthacker Plug and Play Adaptor into the factory turn signal circuit and enjoy Sequential Turn Signals! It’s as easy as that…
Blind Spot Sensors: Positioned exactly to the OE factory location. NO diminished Blind Spot Monitoring or Cross-Traffic Functionality with the use of the factory BSM sensors!
No compromises. All Quake LED Tail Lights are designed to comply with all DOT, SAE regulations for rear-facing lamps. We pride ourselves in offering innovative, stylish, high-performance and safe products for serious enthusiasts.
NOTES:
• Designed to work with North American model Wranglers.
FEATURES:
  • Direct Fit Low-Profile Flush Mount which Protrudes Far Less Than Factory Tails!
  • New B.A.S.S. (Brake Alert Safety Signal) Technology
  • Ultra Cool Startup Animation Effects
  • Running, Brake, Reverse, B.A.S.S. Technology, Standard Turn Signals and Three-Phase Sequential Turn Signals via simplified Lighthacker Technology
  • No Dash Error! Does NOT require any vehicle reprogramming
  • NO Risky Drilling or Body Modification Required! Bolt-on Installation
  • Ultra Bright Reverse Lights
  • Works with Stock Blind Spot Monitoring sensor in the factory position
  • CNC Precision Bent Steel Housing
  • Finished with Durable Black Powder Coating
  • DOT/SAE Compliant Design
  • Mesh Loomed Wiring with Plug and Play Connectors
  • Power output: 25W per side
  • Dust and Moisture Resistant Lenses
  • Bottom Gaskets to Protect Paint Surface
  • Full Color Quake LED Metal Logos
  • Available in Jeep JK, JL and JT Models
SPECIFICATIONS:
  • Light Source: 25-Watt High Powered LED’s
  • Light Color: Red and White
  • Light Pattern: Tail Light
  • Function: Running, Brake, Standard Turns, Sequential Turns, B.A.S.S. (Brake Alert Safety Signal) and Start-up Animation
  • Lighting Voltage: 12VDC
  • Wire Type: Plug and Play with Mesh Loom
  • Wattage: 25 Watts Per Side
  • Amp Draw: 2 Amp Draw at 12VDC
  • Ingress Rating: IP67
  • Laser Cut, CNC Precision Bent Steel Housing
  • Black Powder Coating
  • LED Life Expectancy: 50,000 Hours
  • Operating Temp Range: -40°F to +140°F (-40°C to +65°C)
MODEL NUMBER:
QMT1535 Fits: 2007-2017 Jeep Wrangler JK- Jeep Wrangler JL Flush Mount LED Tail Lights – B.A.S.S. Technology – Sequential Turns – Bright Reverse - Metal Tek Series
QMT1537 Fits: 2018+ Jeep Wrangler JL- Jeep Wrangler JL Flush Mount LED Tail Lights – B.A.S.S. Technology – Sequential Turns – Bright Reverse - Metal Tek Series
QMT1538 Fits: 2020+ Jeep Gladiator JT- Jeep Jeep Gladiator JT Flush Mount LED Tail Lights – B.A.S.S. Technology – Sequential Turns – Bright Reverse - Metal Tek Series
MSRP:
$399.98 Jeep Wrangler JK
$499.98 Jeep Wrangler JL
$519.98 Jeep Gladiator JT
INSTALLATION NOTES:
Installation Difficulty: Easy
Installation Time: 1-2 hours
WARRANTY:
1 Year Limited Warranty
QMT1535 INCLUDES:
  • Left and Right Flush Mount LED Tail Lights – 2pcs
  • Prewired with Tail Factory Connectors (no splicing or wiring required)
  • Pre-assembled Plug and Play Resistors – 2pcs
  • Mounting Hardware Pack
  • Zip Ties – 10pcs
  • Instructions
QMT1537/8 INCLUDES:
  • Prewired with Tail and Radar Factory Connectors (no splicing or wiring required)
  • Blind Spot Sensor Cradle with Hardware Pack – 2pcs
  • Plug and Play Sequential Turn Signal Adaptor – 2pcs
  • Zip Ties – 10pcs
  • Instructions
Jeep Wrangler JL !!!NEW Product!!! Quake Led FLUSH Taillights are live! Featuring B.A.S.S. Technology - QMT1537 6_Flush Ads
Jeep Wrangler JL !!!NEW Product!!! Quake Led FLUSH Taillights are live! Featuring B.A.S.S. Technology - QMT1537 7_Flush Ads
Jeep Wrangler JL !!!NEW Product!!! Quake Led FLUSH Taillights are live! Featuring B.A.S.S. Technology - QMT1537 8_Flush Ads
Jeep Wrangler JL !!!NEW Product!!! Quake Led FLUSH Taillights are live! Featuring B.A.S.S. Technology - QMT1537 9_Flush Ads
Jeep Wrangler JL !!!NEW Product!!! Quake Led FLUSH Taillights are live! Featuring B.A.S.S. Technology - QMT1537 12_Flush Ads
Jeep Wrangler JL !!!NEW Product!!! Quake Led FLUSH Taillights are live! Featuring B.A.S.S. Technology - QMT1537 16_Flush Ads
Jeep Wrangler JL !!!NEW Product!!! Quake Led FLUSH Taillights are live! Featuring B.A.S.S. Technology - QMT1537 4_Flush Ads
Jeep Wrangler JL !!!NEW Product!!! Quake Led FLUSH Taillights are live! Featuring B.A.S.S. Technology - QMT1537 15_Flush Ads
-lenny-
Boyd
Alberta
JLUR EcoDiesel
Kind of a ridiculous price point, but you have a captive market.
Terrymo
Terry
2023 JLURXR 3.6 ET
I think you hit it out of the part with your front fender chop turn signals. I think these tail lights are a big swing and a miss. I’m struggling to see how the designer felt they visually fit in the context of a Jeep.
Deke
2019 JLU 3.6
Looks like 3 cheap LED trailer lights on a piece of bent sheet metal. With almost as many company logos on it as it has lights.
Edit: I had to check to make sure it wasn't April 1st after I posted this. It's that bad.
SadRobot
Los Angeles
2025 Prius LE
Yeah I agree it's a bit odd. I'm also curious about the B.A.S.S technology and how long that lasts. It looks like the same thing I have on my projector alarm clock and the projection part usually only lasts a few months then starts dying.
NPC 20883467
Over the Divide
'20 JL Sport S, '97 TJ Sport
You're being polite... I think they look like homemade shit.
But if this chick would buy them, it would complete the look:
Jeep Wrangler JL !!!NEW Product!!! Quake Led FLUSH Taillights are live! Featuring B.A.S.S. Technology - QMT1537 modified
rivercrossing
Ben
Bronco
I like the red line that is projected on the road behind the Jeep. I think the price is ok. More clearance on the side is a good thing. But the way the 3 light strips are just tacked on the back of these does look a bit home made.
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
Kind of a crazy Mad-Max design, but I like the projecting brake light idea.
Hopefully it tells the person behind you to stay back and/or maybe blinds them just a bit when they tailgate :devil:
Thank you! We wanted to go for a rugged look, to fit in with the rugged offroad nature of jeeps and aftermarket accessories.
It is a super neat feature. No one is doing anything like it, and the uniqueness alone makes me love them, but the functionality and safety aspect is a nice bonus as well!
Notice you are east coast! If you are going to be at Jeep Beach, we have our gladiator down here with these on display, and are also running a small discount :)
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
Not interested in these, however, just ordered the new fenders part #82216497AA.
The problem is obvious.
Slimline desperately needed, the lights confirmed on a separate piece.
Get R&D on the job 👍
Whoa. That's blue! DM me and I can help you get all squared away on your chop kit!
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
One thing I am curious on is how people will like them at night. I've noticed that the longer I have been working in the lighting industry, I have become more aware of what the optics of the lights cause them to look like at night on the road from a far, and not necessarily under a magnifying glass up close. That said there is a balance of course, as I don't want something that looks like garbage on my vehicle either!
Quake LED
Quake LED
Mr. Black
Denver
quakeled.com
JK, JL
50,000 hour life expectancy. If you pay $499.98 for a set of taillights that projector better last! If not we will 100% get the issue remedied, but so far haven't had that go out in all of our testing. These lights are rugged!
