- Mr. Black
- Jul 14, 2018
- Denver
- Website
- quakeled.com
- JK, JL
- Occupation
- Sweat Shop Manger, Slum Lord and Break Dancer
First to market! Sit back and relax JL owners. Our aftermarket plug and play retrofit JL LED Headlight and Fog Lights are here and packed full of features that other so-called LED companies haven’t even dreamt about yet.
This patent pending design headlight comes stock with adjustable High/Low beams, DRL Accent Lighting (Bluetooth controler included), built in Amber Turn Signals and real high power 5W Osram Diodes all jamming through a 4D projector lens design. Our impact resistant aluminum optic ring design provides a watertight seal. Built in our German TUV approved factory and not someone else’s. Quake LED only uses High Quality Diodes, PCB Boards, Resistors and oversized off-road durable Wiring. Durable powder coating and marine grade epoxies will provide you with the comfort of knowing this light will last as long your Jeep does. Try saying that about those mass-produced, el cheapo lights found on the Internet. You get what you pay for.
These easy to install headlights connect with Quake LED’s Easy Link, Quad-Lock Pro and Interlock Controllers giving you endless linking and control possibilities.
LED Head Lights - In-stock
https://quakeled.com/shop/jeep-jl-led-headlight-w-turn-signal-direct-replacement-75-watt-rgb-accent/
LED Fog Lights - In-stock
https://quakeled.com/shop/jeep-jl-led-fog-light-direct-replacement-30-watt-rgb-accent/
