Diode Dynamics
St. Louis, Missouri
www.diodedynamics.com
2018 Jeep Wrangler
Jeep Wrangler JL Meet the D-Switch 8-Channel Switch Panel—Full Command at Your Fingertips | Diode Dynamics {filename}
If you’re looking for full command over your lighting and 12V accessories at your fingertips, Diode Dynamics has you covered with the all-new D-Switch 8-Channel Switch Panel. This advanced automotive switch panel is packed with features to take your setup to the next level—whether you’re building out an off-road rig, overlander, or show vehicle.
Engineered from the ground up with lighting in mind, the D-Switch delivers everything you’d expect from a high-end auxiliary light switch panel, plus some industry-first capabilities that put it in a class of its own.
Jeep Wrangler JL Meet the D-Switch 8-Channel Switch Panel—Full Command at Your Fingertips | Diode Dynamics QNswOlh
Dedicated Backlight Channel. While there are many 8-button controllers on the market, the D-Switch stands apart with a 9th button dedicated to the backlight bus bar. The backlight bus provides eight extra outputs for your accent lights, allowing you to connect all of your backlit accessories without using up any of your main outputs. With just the press of a button, you can now activate all of your backlights at once! This is a game-changer for any rig with multiple lights installed.
Dynamic Channel Assignment. The Diode Dynamics D-Switch is designed to give you complete control over your vehicle’s setup with eight customizable output channels. Unlike traditional switch panels that are one-to-one, meaning Channel 1 is always tied to Button 1, the D-Switch allows you to group and configure multiple output channels per button, allowing you to control multiple outputs with a single button.
Jeep Wrangler JL Meet the D-Switch 8-Channel Switch Panel—Full Command at Your Fingertips | Diode Dynamics ZpB2s4m
You can also power a single output with the different strobing patterns that are included. For example, you can program one button to strobe a light and another to run that same light at full power. Whether you're running Diode Dynamics off-road lighting or any other 12V accessories, the D-Switch allows you to customize each button to do exactly what you need.
Jeep Wrangler JL Meet the D-Switch 8-Channel Switch Panel—Full Command at Your Fingertips | Diode Dynamics 91oxYF
Fast, Responsive Bluetooth App. To activate and use the D-Switch, you can use the included controller, or control it using your phone through the Bluetooth App. That’s where you’ll configure and customize things as well.
Say goodbye to switch panel apps that lag, freeze, or don’t connect. The D-Switch Bluetooth app for iOS and Android delivers instant response and easy programming with no loading screens or connection delays for a seamless and fast experience, every time.
OEM Signal Integration. The D-Switch includes four trigger wires, along with a dedicated Ignition wire for added flexibility. This allows you to control your whole setup using vehicle signals, for a completely integrated experience.
The ignition wire can be wired into an OEM ignition source and will activate the D-Switch when the ignition is turned on. It will also shut things down when the ignition is turned off. No need to manually turn your panel off! If you want to use any outputs without the ignition turned on, no worries - you can still turn the controller on manually at any time.
The three trigger wires provide seamless integration with any of your vehicle’s 12V factory signals, such as high beams, fog lights, or reverse lights. This allows you to activate your outputs automatically–no buttons or switches. With some simple programming, your entire setup can operate like it’s fully integrated on your vehicle.
Lastly, the Night Mode wire can be used to activate certain outputs, such as dimming outputs, or adjusting settings for low-light conditions. This trigger also adjusts the brightness of the controller’s backlighting automatically when driving at night.
Solid-State, Durable Design. Built for extreme durability, the D-Switch features a solid-state design with no mechanical relays to wear out, or physical fuses to replace. The hub is encapsulated with an aluminum heatsink, ensuring superior heat dissipation. The D-Switch is IP67-rated for weather resistance and is backed by a 3-year limited warranty, ensuring long-term reliability and performance. Whether you're off-roading or on the road, it’s built to withstand whatever you throw at it.
Jeep Wrangler JL Meet the D-Switch 8-Channel Switch Panel—Full Command at Your Fingertips | Diode Dynamics CX5yqqg
In the Box:
  • One (1) Switch Panel Hub
  • One (1) Switch Panel Controller
  • One (1) Controller Universal Mounting Bracket
  • One (1) 10-foot Controller Wiring Harness
  • One (1) Trigger Wires + Night Mode Wiring Harness
  • One (1) 3-foot 4AWG Battery Cable
  • One (1) 3-foot 4AWG Ground Cable
  • Two (2) Button Sticker Sheets
  • Five (5) T-taps
  • Six (6) Zip Ties
  • Double-sided tape
  • Installation Hardware
  • Installation & Programming Guide
Jeep Wrangler JL Meet the D-Switch 8-Channel Switch Panel—Full Command at Your Fingertips | Diode Dynamics qtPhe1E
Channel Power: Channels 1 - 4: 15A (per channel), Channels 5 - 8: 30A (per channel), Backlight 15A (total)
Max Current: 125A
Electrical Compatibility: DC
Operating Voltage: 9-16V
Wire Size: 4AWG (Battery), 22AWG (Sensors), 26AWG (Controller)
Operating Temperature: -40C to 120C (-40F to 250F)
Materials: FR4 PCB, Aluminum Casting, ASA Plastic
Cooling: Passive, Pin-Fin heatsink
Intrusion Ratings: IP67 Weatherproof
Product Dimensions (in): Controller: 5.06" x 2.66" x 0.45", Hub: 8.33" x 6.26" x 1.79"
Unit Weight (lb): 1.9
Product Weight (lb): 4.7
Shipped Weight (lb): 5.6
100% Satisfaction Guarantee
Experience. After over a decade in business, Diode Dynamics is one of the most trusted names in automotive LED lighting. We directly assemble and engineer our own products in the United States, allowing for higher quality and performance, with the newest and brightest LED technology. No matter what you're driving, we pride ourselves in offering only the best possible LED solutions. Please contact us if you'd like to discuss your lighting project!
Questions/Concerns. Please go ahead and give us a call at 314-205-3033, Monday-Friday 10 a.m.- 5 p.m. CST, or shoot us an email at [email protected], and our in-house US service team would be happy to help you with that.
Hours: Monday-Friday 10 a.m. - 5 p.m. CDT
Email: [email protected]
Phone: 314-205-3033
Forum Exclusive. All forum members are eligible for a free US shipping code by sending us a direct message.
John C.
Social Media Community Manager
Diode Dynamics
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
There will be vehicle-specific mounts available in the future for both the hub and controller. Additionally, many of our partner brands working alongside Diode Dynamics will offer their own mounting solutions!
For example, Bulletpoint Mounting Solutions is already prepared with a switch panel mount designed specifically for the upcoming Diode Dynamics D-Switch 8-Gang Switch Panel.
Jeep Wrangler JL Meet the D-Switch 8-Channel Switch Panel—Full Command at Your Fingertips | Diode Dynamics JDzPH3R
The mount features all-aluminum construction, ensuring both strength and lightweight durability.
It will be available in two versions: one with a 20mm ball and another with a 20mm connector end.
For more details, visit: Bulletpoint Mounting Solutions
TXSquid78
2024 Willys 4xe; 2005 Corvette
Send some pics when you have one on a Jeep. Curious to know where the mount would be. Dash is perfect for 18-23. 24+ may be a little cumbersome with the bigger screen.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
The D-Switch Controller can be mounted wherever you see fit. It's a universal mount unless you have a 3rd party mount. The controller isn't required to be mounted inside, you can connect by Bluetooth and use the app on your iPhone or Android.
Our team is currently working on an engine mount for the Jeep JL Wrangler for the hub to be easily added.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
600? Must be made of gold
This is not your standard Auxbeam 1-1 control system. This is a performance-packed Switch Panel in line with other top options like Garmin ($500), sPod ($659), PowerSwitch ($499), and BantamX HD ($915).
TEAMSLO
North Las Vegas
23 392, gone 21 JTM & 22 JLURD
Interesting, may need to look into this soon. My previous rig had the elite max headlights and they were awesome.
BigMaCro
Moved to Iowa from Alaska
www.youtube.com
2021 JLU 4xe Rubicon
Carhauler
I really like the features you've integrated. For me, the 3/4 triggers are a big need that others have neglected. Multiple outputs per button, strobe patters, momentary options are great, too.
However, one thing that has been neglected is having multiple power hubs distributed around the vehicle that can be controlled by a single or multiple panels. A trigger or button pressed on one panel could set a "scene" of outputs on multiple panels. I'd like to have one hub under the hood, one at the back or in cargo area, and one on the roof, with controllers on the dash, at the back, and app on my phone.
I bought a Garmin power switch hoping it could do this, but found the app software doesn't allow this kind of setup, and the triggering is poor.
INCRHULK
Lance
Canada
litwphoto.com
2019 Wrangler Unlimited Sahara (retired), 2021 Gladiator Rubicon Diesel
Program Manager, Information Technology
In the Box:
  • Five (5) T-taps
  • Six (6) Zip Ties
  • Double-sided tape
Max Current: 125A
Phone: 314-205-3033
John C.
Diode Dynamics
It would be really great if there was an in-engine bay mount for this.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
2018 Jeep Wrangler
Jeep Wrangler JL Meet the D-Switch 8-Channel Switch Panel—Full Command at Your Fingertips | Diode Dynamics 2019_Jeep_JL_SS5_Straight_Windshield_Grille_Creative_On
That's a fantastic mention, Our team is making an array of mounts for specific vehicles, including the Jeep JL, as our CEO Paul McCain's vehicle is a Jeep Wrangler.
