XR Rubi axles
wfo9
Britt
Toyota Truggy, Tube Buggy on 43s, 4Runner, JLU XR
Keep reading conflicting info just figured someone here might know..
XR package lists it comes with..
  • Dana® M210 Wide HD Tube Front Axle (DJV)
Is this the same as a standard Rubi axle.. I know it has iron knuckles on the XR, but is it any wider or thicker than the regular Rubi axle?
hockeynut258
NW Washington
JLUR
Good question! I’ve been wondering too since the manual cannot be built with the XR package.
wfo9
Britt
My understanding was regular rubi axles had code
DJF
and the XR came with DJV (which is also a gladiator axle)
The main difference being the wall thickness I think.. 7mm vs 10mm. The XR axle also has Iron Knuckles attached and possible a difference sized C thickness and different inner axle shafts and joints.
I think the WMS on both is still 68" but not sure if the iron knuckles or axle itself would change that.
Also someone who recently got a regular 2021 Rubi said there axle was listed as DJV.
zdr
Zach
Central PA
2021 Rubicon V6 6-Speed Manual
DJF
Is the Xtreme Recon package the same on the Willys as it is on the Rubi? Also, can the SELEC-TRAC FULL TIME 4WD be added along with Xtreme Recon?
wfo9
Britt
I think so.. but the lockers, 4:1 low range etc are still exclusive to rubi (it seems).. The big restriction on the XR package is you must have auto v6.. and a similar XR package coming to 392 for 2022.
Select-trac can be added it seems..
