Wrangler Owner Conversion Map: AUXITO LED Headlights
AUXITO
Summit Sponsor (Level 3)
AUXITO
2020 Jeep Wrangler
Products:
AUXITO 9008 H13 LED Headlight Bulb 20000LM 100W Replacement 6500K Plug and Play Off-Road Use
Why choose it?
[ 600% Brightness Improved] The AUXITO upgraded 9008 LED Hi/Lo beam bulbs are 100W per set, providing up to 600% brighter than OEM halogen H13 LED bulbs. 6000K cool white and 20,000LM bring you a clear vision when driving
AUXITO H13 LED Bulb 20000LM 100W Replacement
[Perfect Beam Pattern] The 0.03-inch ultra-thin baseboard makes the 9008 Hi/Lo beam bulbs closer to the light-emitting area of the halogen lamp. 24 pcs CSP chips spread the light evenly on the road and zero dark zone, which makes a safer driving
[ Easy Installation] The H13 LED bulb’ size is close to the OEM bulbs. Almost 1:1 same light filament position effectively simulates stock H13 bulbs’ beam pattern, producing the same light focus. Non-polarity design and the mini size
šŸ›  Installation Hacks from Trail Veterans
The 3-Second Alignment Trick
Rotate bulb 90° before locking – eliminates hotspot gaps in JW Speaker housings.
Use foam gaskets from old halogens if seals feel loose.
šŸŽ Exclusive Forum Perks
15% OFF with code VIP15
Free anti-flicker harness (for lifted Jeeps with voltage drops)
⚠ Critical Note:
Avoid eBay/AliExpress knockoffs! 78% of "AUXITO-compatible" bulbs fail Jeep’s circuit checks. Always verify authenticity via our Official Store.
šŸ‘‰ Ready to Conquer the Dark?
Drop your Wrangler specs below for a personalized bulb recommendation. Our engineers are live in the comments tackling CANBUS issues, flicker fixes, and more!
#LightTheTrail #AUXITOJeepNation
