Wolfbox 4000A jumpstarter.
jadmt
jeff
montana
Face it we all have either needed a jumpstart or run across someone who has needed one. This Wolfbox 4000A jumpstarter is a nice compact package that has a lot of nice features. I have used it to charge my phone and Ipad and both charge super fast and multiple charges are no problem. It has a 3way light feature ie constant on, SOS and strobe. Light automatically shuts itself off after 4 hours to prevent running the battery down. Anyway here is a little rundown on it. These run about $130 but they run sales often and are usually around $100 if I remember correctly. wolfbox.com So far have been really pleased with mine.
Jeep Wrangler JL Wolfbox 4000A jumpstarter. tempImageoAE0rm
Jeep Wrangler JL Wolfbox 4000A jumpstarter. tempImage6RH0ti
The jumpstarter comes in a nice portable case that can be easily carried if you want to use it for charging personal devices away from your vehicle.
Jeep Wrangler JL Wolfbox 4000A jumpstarter. IMG_6712
every thing fits nice and snug in the case so no rattling.
Jeep Wrangler JL Wolfbox 4000A jumpstarter. IMG_6714
The jumper cable handles are nice and solid with plenty of clamping force.
Jeep Wrangler JL Wolfbox 4000A jumpstarter. IMG_6715
Jeep Wrangler JL Wolfbox 4000A jumpstarter. IMG_6716
Wolfbox claims that as long as the charge is above 50% you are good to go. I found it charges up fast and has held a charge very well. when you hit the boost the green start lights up letting you know it is ready to start the vehicle.
Jeep Wrangler JL Wolfbox 4000A jumpstarter. IMG_6718
Nice clear instructions on the back of the unit so no need to worry about losing the instruction book.
Jeep Wrangler JL Wolfbox 4000A jumpstarter. IMG_6717
Has a nice flashlight that works well as a shop light as the light is soft enough but spread out. It also has a strobe and SOS mode. the battery lasts a long time and will automatically shut off after 4 hours of use so you don't accidentally run it dead if you forget to shut the light off. I monitored the the light for at least 14 hours of steady on and the battery was still 63%.
Jeep Wrangler JL Wolfbox 4000A jumpstarter. IMG_6719
Cables just plug in one way no way to mess it up.
Jeep Wrangler JL Wolfbox 4000A jumpstarter. IMG_6720
Just plug it in to the 120V wall socket to charge up.
Jeep Wrangler JL Wolfbox 4000A jumpstarter. IMG_6721
Charges all your devices with no issue.
Jeep Wrangler JL Wolfbox 4000A jumpstarter. IMG_6722
Fits perfect in the back of my JLUR.
WOLFBOX CAR LIFE
Summit Sponsor (Level 3)
Zhong
wolfbox.com
4xe
WOLFBOX OFFICIAL
Thanks for your authentic review Jeff. Our jump starter is your reliable partner!👍
davered00ss
Canterbury Ct
2018 Wrangler 2 door
I did have a chance to use it since I received it. I don't drive the corvette enough, and sure enough when i went to move it out of the garage the battery was dead. The Corvette is finicky for some reason about chargers that will charge or jump it. The WOLFBOX came in with 70% charge when it came in the mail. I put it on the Jumping locations on the fuse box and negative to engine block and it started right up. It later charged to full charge in a very short period of time. Comes in a great case with attachments and charger. Stores away nicely. I think I may buy another to keep one in my truck and the other in the garage
