Mikejt
- Michael
- Dec 21, 2021
- Santa Cruz, CA
- Wrangler Unlimited Rubicon 4xe
It's both, unfortunately. I get both the "cabin heating or cooling" message AND the FORM. When it's hot here (well, for us, it's hot at 80F) I can get it into EV mode by turning off the climate system. Oddly enough, when it's cool (50F, for instance), that doesn't work.What you're describing isn't form. There are some of these that have been having issues with with failure of the electric heater and it will lock you out of electric only use, but you should be getting an error message that says "Electric Mode unavailable. Cabin heating or cooling." It may or may not trigger a check engine light to go with it.
Similar symptom in that it limits electric only use, but not the same thing.
