tpsm
tonycorvettes
tony
2020 jeep wrangler sahara
i changed 5 wheels and tires and tps s now 2 tps wond reset im told u just have to drive it around ,its been 3 days any sugestions?
2nd 392
Ca
i changed wheels and tires now 2 tps wond reset im told u just have to drive it around ,its been 3 days any sugestions?
Did you inflate to 37psi? Will not reset unless you do. Found out the hard way Monday with tires install. After it resets you’re good until 28psi.
tonycorvettes
tonycorvettes
tony
i inflated all to like 38 it sees the front left 38 it sees the front right 36 but dont see the rest i bought a tpsm ts501 it wont relearl teck support says the jeeps wont do that have to auto relearn by driving
tonycorvettes
tonycorvettes
tony
2nd 392
Ca
May have to “See” 37 . Took me 3 tries to figure it out. Good Luck ?
Mudduck
Jay
Michigan
2021 Willys 4door
Mine are the same way. I set them to 37 and drive it for up to 200 miles sometimes before it will read correctly. From what I've been told as well, there is no typical relearn procedure as there was for the last generation TPMS.
FWIW my RAM was the same way.
tonycorvettes
tonycorvettes
tony
ok il try that i put all to 37 lbs
Spartan99
US
2008 JKUX
One of the best mods on my Jeep was disabling TPMS. Can you do that on these year Jeeps?
tonycorvettes
tonycorvettes
tony
this is the dumbest tpms ever,,no way to reset it no way to reprograme it your supposed to acording to jeep manual drive over 25moh for around 20 min i have driven for days and still i have one wheel not showing any thing it relearned 3 of them ,,i hate to go to the dealers dont trust them
tonycorvettes
tonycorvettes
tony
this is the dumbest tpms ever,,no way to reset it no way to reprograme it your supposed to acording to jeep manual drive over 25moh for around 20 min i have driven for days and still i have one wheel not showing any thing it relearned 3 of them ,,i hate to go to the dealers dont trust them i found the problem the ecu has memeory of the oem tps from the factory i changed to aftermarket they would not relearn all 5 i put my oem s back and i drove like 1/4 mile and ne damn if ot cleared and i put air like the door sticker showed 38 lbs
tonycorvettes
tonycorvettes
tony
thanks everybody for your input
tonycorvettes
tonycorvettes
tony
fixedddddddddddddddd i put back my nfactory oem tps and putb 38 lbs of air and vala it cleared after driving 1/4 mile ////stay away from aftermarket or even chainging oem s to new oems the ecu is programed to your factory tps thanks guys for your input
