to which would you switch?
MyDaughters20JL
WA
20 JL Sport S
'20 JLU Rubi
Aftermarket F&R bumpers
Apex winch
R/C 2.5" spacer lift
I notice a slight forward rake now, without the winch (my plans are to install it this coming weekend), thinking of just upgrading the front springs to ones for the diesel rubi...BUT!
Because, I've been told, the wranglers (with the exception of the diesel) are heavier on the left side, the spring numbers are (usually just one number) larger on that side.
666/667 combination on my rubi, or pair up the 666's?
thoughts on your choice, please
Chief20
J
New York
Wrangler Jl
I would see how much its off. If it really bothers you, you could swap your suspension for a diesel since the front springs are the same and the rear springs are the same but the fronts are longer than the rear. Then you can see to add a smaller spacer lift or same one depending upon your results.
