surferbandit
- James
- Jul 6, 2018
- Atlanta Georgia
- 2018 Jeep Wrangler JLU Sport
Up for sale is a teraflex 3.5 inch lift kit with shocks. I ended up trading my Jeep in on a 2 door and needed a different lift kit. The box has been opened to verify parts but never installed. Asking 675 but feel free to make me an offer. I’m in Lawrenceville and prefer to do a local pick up.
From manufacturers site
Bolder Off-Roading Capacity. Teraflex offers this 3.50-Inch Coil Spring Base Suspension Lift Kit with 9550 VSS Shocks to give your JL an improved ground clearance and enhanced off-road performance. It includes basic, high-quality suspension parts to achieve superior geometry, roll center, and load tuning for significantly improved off-roading while maintaining excellent on-road handling.
Premium-Quality Shocks. This Suspension Lift Kit includes 9550 vehicle-specific shock absorbers to significantly reduce the vertical impacts. These shocks are particularly engineered with precise valving and tuning for comfortable off-roading and smoother on-road driving. The twin-tube design and travel limiter facilitate longer stroke travel and minimize the impacts of over-compression. Moreover, the durable, black e-dipped finish reinforces long-term functionality with the added resistance to corrosive attacks.
Heavy-DutyShot-Peened Coil Springs. The Lift Coil Springs in this kit are designed to improve your JL’s off-roading stance while providing smooth and controlled rides. They were particularly engineered with optimized rate tuning and dynamic balance to deliver steady performance without the unwanted bouncing on rugged trails. Moreover, these coil springs were shot-peened and reinforced by a powder-coated finish to hold up well with the rough off-road rigors.
Bump Stops Kits. The bump stop strike pad kit in this suspension system is included to ensure proper bump stop lengths. This is critical to prevent damage to the suspension components and shock absorbers. These strike pads extend the effective bump stop length by 2 inches. In addition, this lift kit also comes with a 0.50-inch front and rear bump stop strike pad shim kit to accommodate tires up to 37 inches.
Bolt-On Installation with Mechanical Expertise. This Base Lift Kit is designed as a complete bolt-on upgrade. It reuses the factory mounting locations on your JL’s suspension system and includes all the necessary hardware. The installation process completes in about 5 hours with mechanical expertise required.
Lifetime Warranty. TeraFlex Inc. warranties that the components of this 3.50-Inch Coil Spring Base Lift Kit will be free of defects in material and workmanship for as long as the original purchaser owns the vehicle on which products were originally installed. Some exclusions may apply; please check the terms and conditions for full details.
Application. This Teraflex 3.50-Inch Coil Spring Base Suspension Lift Kit with 9550 VSS Shocks is intended for use on all 2018-2024 Jeep Wrangler JL 4-door models.
