This is correct for the F5 based Flashcal and Flashpaq devices. Return to stock and they unlock themselvesIf the settings are reverted back to stock it can be used on a different vehicle. I checked with quadratec and superchips.
So this technically doesn’t reflash or change the tune. It recalibrates the speedometer for bigger tires, gearing changes, and other misc options.So explain how this works? Just plug it in, Choose the tune, Tune it then unplug it? Or do you have to buy the tune first? Is this for the 2.0 or the 3.6? Does it work with the E-Toque?
This flashcal can be upgraded to a flashpaq to add tuning. Once upgraded, you'd submit our PCM swap to have us send you an unlocked PCM, then you install it to the vehicle. Once thats done, you can use the f5 to load one of our dyno developed performance tunes to the vehicle for more power and performance.So explain how this works? Just plug it in, Choose the tune, Tune it then unplug it? Or do you have to buy the tune first? Is this for the 2.0 or the 3.6? Does it work with the E-Toque?
