Screw size for rear window bracket?
JSFoster75
Bluff City, TN
Does anyone know the screw size for the lower bracket on the rear glass pistons on the 3 piece hardtop? There is 1 bracket on each side that has 3 screws, I stripped one out removing it to attach a different bracket...
Carolina Jeeper
Rollie
North Carolina
Should be able to get a match or close match at the local hardware store and some parts stores. The problem you'll run into is length so you may need to buy one with the correct threads but too long. Just trim the length and install.
JSFoster75
JSFoster75
Bluff City, TN
I figured out that it is a M6 x 18 (6mm x 18mm), but all I could find at Lowes was a M6 x 16, it worked fine, just didn't thread as deep as I would have liked.
