MuffCrawler
Asking 7000
Based on a M1102 chassis trailer, 7000 torsion axle, pintle surge brakes. Aluminum and stainless steel. I have towed it with my wrangler with no issues. Came with 37 run flats, replaced with 285/75x16. Both tires are about 90% usage. Suspension has been lowered to accommodate civilian vehicles, but it will follow your vehicle to any trail, you can see the clearance. Additional spare tire.
Multiple fixtures outside where you can add your additional equipment
Lockable undercarriage space with rear hatch.
All lights and markers working with no issues, replaced the original 10 pin to a standard 7 pin plug
21 Gallon Water tank with Jasco water pump. Lateral fill in port and water quick disconnect port.
Campflux water heather.
Slide out Kitchen, with heavy duty stainless steel sliders rated 500 Lbs. Coleman Kitchen.
Slide out Freezer tray
Back storage
Privacy shower tent
Back, sides, interior LED lights
High-lift Jack
Recovery boards
Sleep three with space, AC/heater/Fan unit
110 AC hook up.
1500 watt power inverter
Dual jerry can mount
20L propane tank mount
Rear camera system mounted on trailer with 7" display to set on towing vehicle.
Carpet inside. Exterior painted with green raptor liner. It has been parked for a while, meaning I don't use it. Registered, Title in hand. You will need a pintle connection to tow it. Local Pickup only.
Back storage
Privacy shower tent
High-lift Jack
Recovery boards
110 AC hook up.
