JeepAustinWeird
- Steve
- Feb 20, 2020
- Austin, Texas
- 2018 JLU Rubicon
I noticed a scuff on my front driver's bumper making me think someone has probably backed into me.....so I starting looking around pretty thoroughly inside the bumper, frame, and under the Jeep and didn't notice anything bent or out or whack on the bumper, front lights (including light bars, and fog lights), and inside (thank the Lord), but did notice some narrow gapping between my front springs and what I (in my novice knowledge) think is the attachment point of my sway bar. The gapping is much narrower on the drivers side which is the side that the bumper has scuffs. I even measure the opening gap between my bumper and grill and it was even all the way across.
I have the Mopar lift (2" with Fox Shocks) and have 35" tires...so for others out there with similar or same, can you check your set up in comparison with my pics and please let me know if what I have is "normal". I am hoping it has been this way since the lift was put on (at delivery of vehicle), but I drove around today doing a lot of turning and up and down incline and never heard any sounds of one piece contacting the other. At one point I put each front tire up on a rock to check with flexing of the frame if it would contact each other and it didn't. I've posted pics of just Driver wheel b/c it seems with the driver wheel up it narrowed the gap more than with passenger wheel up on the rock. I guess I'm also looking for a little reassurance that if the connection were pushed back towards the spring, the two components will still never contact with frame and wheel articulation both with and without sway bar disconnect. In other words I'm hoping that the way things sit it is normal, but more importantly, if not, there will not be a situation that this will affect drivability on and off road of my Jeep. I even stood on my step bar bounced my Jeep up and down and didn't look like the gap narrowed by much.. I feel like I am being overly anal about this but since my Jeep is my Baby, I want to make sure it's in tip top shape. Thank in advance for reading and helping with advice and info.
Front Bumper
Driver's side (parked on flat ground)
Passenger Side (parked on flat ground)
Up on a rock
Gapping on Drivers side with wheel up
Front Bumper
Up on a rock
