OEM LIGHT SWAP
MCARV482
marc
RI
2024 WRANGLER SPORT S
I am new to the wrangler world. I am upgrading all lights on my 24 sport s to the led's. I upgraded the fender flares with the paint to match led from a sahara. I know i need to go to dealer and get the headlights and fog lights flashed. Will this also make the Led on the flares work?
OminousSkitter
The Ether
Trek Bicycle
You mean in general work or as DRL? Flashing for LEDs should get them to work in general, but your sport might or might not have the wiring for the side/fender flare lights to be DRLs.
MCARV482
marc
RI
to work in general/ the left side will flash intermittent. The right nothing. Also if could be as DRL that would be a huge bonus. So once flashed they should be working / if not a drl then once switched on they should work as designed?
OminousSkitter
The Ether
Trek Bicycle
Should be the case, though I have no personal experience with that. My Sport doesn't have the wiring to be DRL, but I have LED switchback bulbs there (that didn't require a flash).
Fish
Darren
Southwest Michigan
2018 JLU, 2019 F150, 2023 Subaru Outback XT
Boat Sales
BUY A TAZER AND THEN YOU DONT NEED TO GO TO THE STEALERSHIP. Sorry for the caps, at work always typing in caps lol
aeonixx1001
Kim
Arizona
2020 Jeep JL
Agree, just buy a Tazer (mini). Save several trips to the dealer.
aeonixx1001
Kim
Arizona
2020 Jeep JL
Maybe I'm missing something. Why would you have to "Flash" anything Plug your headlight in and go, unless you didn't get the load resistor type (CAN) I believe they call it. If you want side DRL's run a line from your fuse box from a terminal not being used that only turns on when the ignition is on. Like cigarette lighter, heated seats. You can hard wide both sides in parallel So when the key or button is pushed they come on. Buy a Mini Tazer or at least check them out...
OminousSkitter
The Ether
Trek Bicycle
He swapped his halogen fender flares for painted, LED Sahara fender flares. He didn’t just put LED bulbs in a halogen housing. Swapping anything halogen for OEM LEDs requires flashing, no?
aeonixx1001
Kim
Arizona
2020 Jeep JL
Oh, I missed that entire point and I have no idea. My apoligies
