JMP
- Jason
- Nov 2, 2022
- Little Rock AR
- GLI, Tiguan, Buying a JL
I'm going insane trying to figure this out.
Where exactly are the axle oil seals on the FAD (passenger) side?
1) By the pumpkin?
2) Outside the FAD?
- Should the FAD have gear oil from the diff inside it to lube the sliding collar?
Can anyone provide a link to a some sort of diagram that explains it all? I found an exploded view with numbers pointing to the various parts, but no key to describe what the numbers mean.
My FAD is leaking gear oil after a re-gear and I'm trying to figure out if it's an axle seal problem or a FAD seal problem.
Thank you!
1) By the pumpkin?
2) Outside the FAD?
Thank you!
