The Teraflex spacers are easy to install and they are stackable if you need more than 1/2".I really hate the rake look and I want the jeep to set level. My plan is new rims/35" tires, my question is will leveling spacers work OR should I replace the springs and will that level out the Jeep?
I'll let someone more knowledgeable answer but I would imagine one of the issues you could run into if you add too much height would be the shock length possibly getting maxed out. A 2" level seems like a lot on top of a lift (spacer or spring).So adding spacers say 2" will I need to replace anything else to match the change in height?
