JLUR versus JKUR wheels
MarkY3130
Denver
2019 JLUR
Are they the same bolt pattern and offset or?
Sure would be nice if JK wheels were same as JL wheels.
Thanks
Bolt pattern is the same and I believe the offset is the same or very close to the same. However, I believe the studs for the lug nuts are larger diameter and the center bore is larger diameter. (On JL). Meaning, the JK wheel may not fit over the stud, and the center bore may not fit over the camera on the spare. Some wheels that worked on the JK may work on the JL, but not all. (Aftermarket, not sure about OEM JK)
kkuntz01
Kevin
Mount Juliet, TN
2018 JLU Rubicon, 2014 Ram 2500 Crew Cab
The bolt pattern is the same 5x127 (or 5x5) though the bore for the lug nuts might be a little larger on the JL wheels than on the JK due to the 14mm studs (JL) vs 1/2” studs (JK). Based on what I’ve read so far the rim width and offset sound like they’re the same.
