danzy55
I believe that steel rim is from a Dodge Dakota, not sure of the size but look at 80-90's Dakota steel rimsSomething like these maybe...
Our bolt pattern is 5x5 that one for the Dakota is 5x5.5, so no go.https://www.roadreadywheels.com/products/2005-2011-17x7-5-dodge-dakota-steel-wheel-rim?msclkid=8af32a59478b1a6309214a1ee148c8e5&utm_source=bing&utm_medium=cpc&utm_campaign=BPA - Items - Dodge&utm_term=4582352164389554&utm_content=BPA Item - Dodge|Dakota|80-100|C:70
Here you go! Not sure if they will fit a JL but they are cool and cheap!
Thanks for the super detailed post and photos, that setup looks awesome.Resurrecting this thread in case anyone is still looking for a good wheel tire combo. I think I may have found the perfect combo of wheels and tires for a "military" or old school look for the JL as far as wheels go. Strap in, this is a long post...lots of info, lots of spec, and most importantly lots of pics!
Here's the setup:
Goals of this setup and notes:
- 2018 JLU Sport S, 3.6l Gas, Auto, 3.45 gears, and Mopar 2" lift
- Tires: 285/75R18 Goodyear Duratrac
- Specs: 35.1" tall, 11.2"tread width, and 18" rim
- I wanted to run this tire due to it measuring as a true 35" tire and it's the same width as stock Rubicon tires (11.2")
- I've run these tires on a past 4x4 van with great results, I just love Duratracs for year round driving in Colorado
- Wheels: 18x8 stock steel spare wheels from Grand Cherokee or Durango
- Specs: 18x8, +56mm offset, 71.5mm hub bore, steel
- Part number: 04755212AC (there are several variations of part numbers but this should get you started for your search)
- I hate flashy wheels, honestly the rubicon wheels with the silver lip is just ugly to me. I wanted a classic steel wheel look. This was the hard part because nearly no one makes an 18" steel wheel! Luckily Mopar took take of that while making spare wheels haha
- They are +56mm offset...so this brought them in +12mm closer than the stock Rubicon wheels (+44mm) I had on before. When these new wheels/tires were mounted I had rubbing on the sway bar and control arms. Of course I knew this would happen, so spacers were in order.
- Extras: 1.75" wheel spacers
- Specs: G2 5x5 1.75 Wheel Spacers...its important to get a JL specific wheel spacer to match thread length/type and hub size
- Part number: 93-73-175M
- These were needed to combat the rubbing I experienced with the added offset of the rims.
- This makes the wheel/tire combo stick past the fender nearly identically to a 35x12.5R17 tire with a +25mm offset...AEV recommends this set up for their JLs
- Now I know some people are against spacers, but I see no issues. Just be sure to use the supplied RED loctite, PROPERLY TORQUE and CHECK TORQUE after a few hundred miles after initial instal, during tire rotation, and after heavy trail use. Sorry for the CAPS but this is important!
Now you may be wondering what this costs. For me I'm not in a hurry to buy new condition parts at the store/online for my Jeep. I constantly check Craigslist and Facebook Marketplace for good deals. Here's what the final cost for everything needed for this set up:
- Wanted a true 35 inch tire without the added width...the Duratracs accomplished this with their 35.1" height and 11.2" width
- Classic/rugged wheel look...the Grand Cherokee and Durango full size steel wheels look awesome in my opinion
- Did not want the tires to stick out past the fender flares more than necessary...the combination of high offset (+56mm) from the wheels and 1.75" spacers are near perfect. Nearly identical to AEVs wheel/tire recommendations.
Final thoughts...now I'm only a few days in with this setup.
- Tires: bought off Craigslist for $1300 for set of 5
- 285/75R18 Duratracs are coming from the factory on the new Ford Super Duty Tremor packages. So keep an eye out for people taking these off and selling them! I grabbed my BRAND NEW set of 5 take offs for $1200 from a guy that just upgraded his truck when he bought it
- Wheels: bought on Craigslist for $225 for a set of 5 never used wheels from a Dodge Durango
- Spacers: unfortunately I didn't have time to source these and needed to combat the rubbing immediately...so $240 plus tax for G2 5x5 1.75 Wheel Spacers specifically for the JL
- SO total cost for this set up $1665! Compare that to buying some new flashy wheels and wide tires that could possibly rub. I know the look isn't for everyone but I love it!
Well you've made it this far so here's pictures haha...the rear pictures show how much they stick out, I didn't do a close front picture since I need to center my axle with a new track bar and the distance on each side is off...but the other pics should give agood idea of looks.
- I had an AEV Pro Cal Snap to reprogram for the larger tires...matches GPS speed and shift points are good
- On-road I have no rubbing at all!
- Off-road...once I hit the trails I'll check clearance and report back. Based on all the calculations I've done, I don't anticipate any issues.
- Driveability with 3.45 gears and 35s really is not bad. I also have a hard top, rack, and roof top tent (iKamper) so there's all that added weight. I drive pretty conservatively and cruise around 65-70 MPH on the highway.
- MPG...now this is still up in the air. So far with about 200 miles the computer is showing 22.1 MPG with I'd say a 80/20 highway/city split. I won't know true MPG until I hand calculate after a few tanks of gas
Here's an option, Mopar Winter/Offroad steel wheels.
Anyone know if the size and backspace on the JK is same as the JL?
