California JL/JT Custom Bump Stop Extentions
gevo1
George
Los Angeles, CA
2019 Jeep JLUR
Custom made aluminum bump stop extensions.
x2 JL/JT Front 1"
x2 JL/JT Front 2"
x6 JL/JT Front Spacers (can be stacked to adjust)
x2 JL Rear 1"
x2 JT Rear 2"
Comes with bolts/nuts.
Asking $100 for everything. Located in So-Cal, Granada Hills area. Don't want to ship.
Also have other things for sale. Going to list them with details:
- EVO Plush Ride 2.5" springs Front & Rear for JLUR. $200
- JL Rubicon Factory Red stitched steering wheel, non-heated. $150
- Synergy JLUR Tie Rod (comes with Fox Tie Rod Clamp). $300
- Synergy Drag Link. $200
- JLUR Factory Rubicon Sliders. $70
- JL Rubicon Steel Bumper LED Fogs. $80
- JLUR Factory Suspension. $200
- JLUR Factory, all 8 control arms. $150
- JT Rubicon Factory Drag Link. $100
- JT/JL Rubicon Factory Tie Rod $150
- JT Rubicon Factory Rear Track Bar. $50
- JT Rubicon Factory steering stabilizer. $20
- Teraflex Tie Rod clamps both 1.5" diameter with different thread sizes (haven't bothered to check since I never used them). $40/both
- JT Rubicon launch edition wheels/tires and spare. Factory 33" Falken Wildpeak A/T tires. 1 day old. $1,500
- Teraflex JT Rubicon 2.5" suspension lift with 3.3 shocks. $1,900
Thanks for looking.
- George
Jeep Wrangler JL JL/JT Custom Bump Stop Extentions 20210919_170924
Jeep Wrangler JL JL/JT Custom Bump Stop Extentions 20210919_170247
Cypher
J
AZ
Cybersecurity Leader
if you decide to ship let me know. I am looking for 1" front and rear bumpstop extensions.
Cypher
J
AZ
You need only the 1" front and rear? I can do $50 shipped.
Correct, i am just looking for 1" front and rear. I have a diesel with the longer jounce tubes, so think 1" extension with Mopar lift may work perfectly to get a bit more travel back . Worth trying anyway. PM me and ill give email for payment
gevo1
gevo1
George
Los Angeles, CA
2019 Jeep JLUR
I am unfamiliar with the Diesel suspension. However, as a precaution, If the Mopar kit is designed for the Diesel, then I assume they added the correct amount of bump stop extension to the system. Reducing this amount may cause you suspension bump travel to be limited by the shock itself instead of the bump stop..
yachtclub
Nick
Vancouver, BC
2020 Jeep Wrangler Sport S Altitude Edition - EcoDiesel
Hi there, I'd take the front 2" bump stops if you would ship to Washington 98281. How do they mount? Looks like the hole doesn't go all the way through? Is there a stud embedded? Thanks.
gevo1
gevo1
George
Los Angeles, CA
2019 Jeep JLUR
Hello, sure. I made these myself so they are flat faced and don't mess up the strike pad of the hydraulic bump stops. Its threaded from the back but not fully through. You get long all thread which can be cut to length depending on the amount of additional spacers you want to add. It threads in and bolts through the factory hole on the spring perch (I believe you may need to size the hole up a bit if I recall correctly). Nut goes on the bottom with loctite and you tighten from the top puck via hole on the side which you can place a screw drive or similar into and turn.
yachtclub
Nick
Vancouver, BC
Cool, sounds good. Want to DM your paypal info and I'll shoot over my shippng address? Thx
