Texas JL AUDIO FIX86 NIB
abill
2018 JLU
I have nib JL FIX 86 DSP for sale. I bought it for an install but then my installer opened it up, looked at it and said that it won't work for me and recommended the pac amp-pro device instead. I did not know enough about it to say otherwise so I am getting the Pac device from him and trying to get some of my money back on this.
Asking $425 shipped, located in Texas
Biconia
Kenny
Los Angeles CA
2018 Rubicon JL
Probably your installer doesn’t know how to use that unit i have installed on my JL and still sound Crispy and work perfectly, i moved from Pac Amp to JL Fix
good luck with the Sale
abill
2018 JLU
What did the fix do better than the pac? I wish I knew more about installation of these and I would just try it myself but he said something about I would need another t harness (already running 2 amps, one small one for components and a larger one for subs) and it would not retain steeling wheel controls? I must admit, that one didn't make much sense at all to me as for this thing is only controlling a signal that is straight out of the head unit to the amp, correct?
Biconia
Kenny
Los Angeles CA
2018 Rubicon JL
Woe you need to look for different installer brother
here is link how to setup aftermarket sound system
https://www.jlwranglerforums.com/forum/threads/adding-an-aftermarket-amp-s.6568/
abill
2018 JLU
Well crap. I wish I knew more about these things and could get out there and do it myself. The second amp and subs they added sound fine but the other components sound terrible still and need some kind of help, hence why I bought the FiX.
The components are powered by the little alpine power pack unit only rated for 45w per channel and was told that its crossover isn't doing a great job at isolating the frequencies so there is a light hiss you can hear when volume is off, or down low. Said that a new, more powerful amp would be a good thing to replace too, that the cross over would do a better job and could give the speakers more power, that sound reasonable?
Biconia
Kenny
Los Angeles CA
2018 Rubicon JL
So do you have Pac Amp currently?
if you have Pac Amp thats the reason i moved to JL FIX
abill
2018 JLU
no current pac, it had to be ordered.
Biconia
Kenny
Los Angeles CA
2018 Rubicon JL
If is not too late look at that Page ( Link )
Go from there and stay away from your current installer
abill
2018 JLU
I'll try but all that soldering, resistors, and all the hookups on the side of the Fix confuse the hell out of me. If I could just add an extra RCA cable and put it inline I feel I could do that I think but the other stuff is a little out of my wheel house but then again I have never really tried. At the moment I have little time to devote to it so I wanted to just take it somewhere and let them do it.
Biconia
Kenny
Los Angeles CA
2018 Rubicon JL
Its very detailed instructions from that link or some other installer may be familiar with this
Good luck brother
