- Infotainment
- Oct 24, 2024
- Oviedo, Florida
- Website
- infotainment.com
- Various
- Occupation
- Infotainment.com
Hey Jeepers,
If your factory touchscreen or control module has started acting up, you’re definitely not alone. We see the same problems pop up often right after the factory warranty expires. At repair.infotainment.com, we offer OEM touchscreen and module repair & replacement services designed to get your factory system working like it should again without resorting to aftermarket units or costly dealer replacements.
What We Repair
Our repair services cover a wide range of factory infotainment systems and electronic modules, including but not limited to:
Common Touchscreen Issues
If your factory infotainment system isn’t working the way it should, there is a reliable OEM solution. You can explore repair options or reach out to our support team directly at repair.Infotainment.com
Have Questions?
Our U.S.-based team is ready to help:
Call: 1-855-636-6287
Email: [email protected]
What We Repair
- Unresponsive or “ghost-touching” screens
- Cracked or scratched digitizers
- Black, blank, or flickering displays
- Slow or lagging touch response
- No power / no sound
- Reboot loops or system freezing
- Internal memory (MMC) failures
- Wireless module or communication errors
- GPS stuck loading or failing to locate position
- SiriusXM® tuner failures or antenna connector damage
- Bluetooth pairing or audio issues
- Outdated or buggy software
- System lag or random glitches
- Repair Service: We restore your original OEM unit using professional diagnostic and repair methods.
- Replacement Service: If repair isn’t ideal, we offer OEM replacement units to minimize downtime.
