Hyperflash via Fabtech Fender Flare with Quake Led
SCOOTTKE283
2020 Jeep Wrangler Unlimited Rubicon
Recently purchased a used 2020 Rubicon with tons of shop installed aftermarket parts. After the recent weather spat in TN my drivers side blinker (turn signal) began hyperflashing and stating the turn signal is out. From everything I’ve read on quakes website I should not be seeing any hyperflashing or turn signal out message. My first indication is to remove the inner fender liner and disconnect the quake led and reconnect. Also kinda strange is that on these fender liners it appears they leave the turn signal harness exposed to the elements? Is that the normal thing on newer Jeeps? My 2011 rubicon I had everything snaked and taped. Any suggestions would be great!
MichaelAnthony
Michael
Aliquippa, PA
2019 Wrangler Rubicon JLUR, 97 Centurion Dually 7.3, 97 Classy Chassis Dually 7.3, 2016 Ultra Classic CVO
Do you have pictures of the set up? Kind of hard to tell what all you have without looking at it?
