How Can We Help?
MrSchwifty
Barcelona
Wrangler Rubicon 2 Door
Hi Chris,
Yes we do. Your part numbers are correct BTW. For total costs please add the items to your cart and supply the full shipping address. Here are links
https://parts.allmoparparts.com/oem-parts/mopar-air-conditioning-probe-68301849aa
https://parts.allmoparparts.com/oem-parts/mopar-oil-feed-tube-68300422ab
I will send a code you can use as well
- Benny
Thanks for your fast response.
I placed my order earlier this morning and have sent you a DM in relation to the order.
RubyRuin
Frisco, TX
2026 JLRX 6MT
Hello Benny, just picked up my 2026 Rubicon X and it's already got the tailgate reinforcement installed --looking to see what you guys could do for the oversized spare tire kit (82215355AC) and also confirm this is in fact the correct part number for the 2026; for some reason different vendors state this fits and some don't.
Thanks in advance!
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Thanks in advance!
Hi,
This is confirmed for the 2026, Here is a link to it https://www.allmoparparts.com/sku/82215355.html
I will send you a code you can use when ordering.
Thanks!
- Benny
bigblue
Roaming PA
18 wrangler JLU OBM
Benny,
2018, JL Unlimited Sport S, 3.6 V6. I'm needing the following:
1. Front brake calipers ( Driver and Passenger sides)( come with the bleed screws?)
2. Front brake soft lines that attach to the calipers ( both sides)
3. 4 sealing washers for the caliper banjo bolts ( to attach soft lines to calipers)
4. 4 slide pins for the front calipers
5. Front wheel bearing hub assemblies ( both sides)
6. 2 axle nuts ( for the hub assemblies)
Can you confirm those Part #'s for me? I can PM you my VIN# if needed. There are a few items there, so a good price would be greatly appreciated. TY
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Benny,
Hi,
Yes please PM me your VIN
Thanks
- Benny
chrissyssahara
Chrissy
Mountains of PA
JEEP Wrangler Unlimited Sahara
Hi Benny,
I hope you can help….im going nuts trying to figure part numbers & so on….I need a list with the part name, part numbers and pictures for the factory Sunrider soft top that came with the dual top package for my 2018 Sahara JL 4 Dr i bought…I went to take the freedom top off to put the soft top on and realized that the windows are missing and several other pieces. The twill top & some parts are there but I need to look at a picture so I can compare what pieces I have to the picture and figure out what they’re called and get the numbers so I can order all this stuff. I want the Twill tinted windows not to clear. VIN is
Hi Guys!
We are pleased to have the opportunity to support such a dedicated and enthusiastic forum. As an authorized Mopar Parts and Accessory retailer we are here to help answer any product questions you may have. We also welcome any part inquiries you may have no matter how big or small. I should also note we have some of the best pricing around :rock:
Please feel free to reply here with any inquiries!
Thank you,
Benny
Hi Benny
Do you have a parts list that includes the part number, a picture of the part and what the part is called for the factory Sunrider soft top in Twill …the premium top that came with my dual top package for my 2018 Sahara JL four-door that I bought in November? I just looked at what came with my jeep and I am missing the windows and some other parts so I need to do a comparison and figure out what parts I’m missing & the numbers. I do want the twill tinted windows instead of clear thank you for any help …my vin is 1C4HJXEG6JW131768
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi Benny,
Hi Benny
Hi Chrissy,
Take a look at this install link as well and the pic below and we should be able to get you what you need
https://www.allmoparparts.com/docs/82215146.pdf
Jeep Wrangler JL How Can We Help? 1774654516031-o2
In regards to tinted windows these are only available for the rear and quarter windows, Not driver and passenger.
Let me know what questions you may have after reviewing this
- Benny
chrissyssahara
Chrissy
Mountains of PA
Hi Chrissy,
- Benny
I think all I need are the rear & quarters. Driver & passenger would be the existing glass no? Looks like what I need are JLWINDOW4DPT, 68251540AE & 68251541AE ..... any military discounts? Shipping is pretty crazy 🤪 120+26 ?? Damn wish I didn't want tinted so bad. I'm confused because the black diamond vinyl windows both the clear and the tinted are the same price but with the twill the clear windows are about $300 cheaper than the twill with the tinted windows. Is there a reason for that? Ty!!
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
I sent a code you can use. Your part numbers are correct for your application. Yes this is most likely due to popularity , The clear is more rare.
Please let me know if you have any other questions at this time.
Thank you,
- Benny
Penguin07
New Hampshire, USA
2021 Jeep Wrangler Unlimited
Hello,
I am looking to do an LED headlight upgrade for my 2021 Wrangler Unlimited Sahara.
When I go through the site for 82219141AA (https://www.allmoparparts.com/sku/82215136ad.html), it says I may need a different harness (68414409AB) than the one included in the kit, or I may not even need to use the one that's in the kit. How do I find out if I do need the different harness or if just the kit is enough, or don't even need to use the one in the kit?
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hello,
You should not need the harness included with the kit. As for the smaller jumper we have found this mostly on Gladiators but to be sure you would have to disconnect the existing jumper to see which pins are present. If you can snap some photos of each connector and send it over I will verify. This jumper is located on the drivers side headlamp connector.
- Benny
Penguin07
New Hampshire, USA
- Benny
Gotcha. Thank you for the response.
I guess worst case, I'll just install it and if DRL doesn't work (I'm assuming the extra harness/cable is for the DRL portion), then I'll reach out then.
On a side note, the passive entry kit I got from you last week and put onto my car this past weekend works amazingly. I got it real quick too haha, so thank you.
chrissyssahara
Chrissy
Mountains of PA
Hi,
Thank you,
- Benny
Thanks Benny! I just finished ordering and I added the cute little army paratrooper tire cover for good measure since you saved me some money on a Fort Bragg army brat thank you so much. I really do appreciate this so excited.!!
Hi,
Thank you,
- Benny
thank you, Benny!!
I just ordered everything and I added the very unique army paratrooper tire cover for the back of my jeep for good measure and since you saved me some money!! I am a Fort Bragg army brat, Husband a Vet & stepdad flew C130s for the USAF. absolutely perfect cover for my O|||||||O
I’ll be buying all my parts from you guys. God bless! -Chrissy
