How Can We Help?
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
I’d like to know how to escalate my gorilla glass claim. The windshield pretty much shattered from a small impact!!!!
Hi Bob,
I would refer you to chat with Jeep Cares, We are an independent dealership not Mopar corporate.
- Benny
Rico1111
Rico
RI
2018 Rubicon 2 door JL
Hi Benny..any chance you can find the part number for the new window alignment pieces for the soft top? On another post someone with a 22 had a picture of a new end piece on the top side curtain rails (looks flat and elongated) instead of the previous white cone tip.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
Can you point me to that post so I can understand better what were lookin for.
Thanks,
- Benny
[DELETED USER 82058]
Alabama
2022 JL Rubicon 2-Door
Ordered a couple of things from you guys, only complaint is the last piece came in with a bend in the plastic that made that piece turn white. It was the driver wire cover/tread plate. Luckily the piece was the removable cover so I just reused my original. But your communication is top notch!
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Thanks for your support and I am very sorry about that. We can certainly exchange it if you'd like?
Thanks again!
- Benny
Altitude2020
Canada
2020 Jeep Wrangler JLU Altitude
That's interesting Chris, This part number is a standard production part used on the new Grand Cherokee and various other models. I will keep this in mind incase anyone else asks in the future.
Thank you for sharing,
- Benny
Here is a picture of the parts bag and item. I find the part isn't a perfect fit on it's own. I think there should be an insert of some sort. The tube door is a thicker metal than the actual gripping part of the rubber bumper. I tried to insert the rubber bumper and so did the dealer. They ended up using silicone. However, there still is a problem with the door so they are replacing it with a new door.
Jeep Wrangler JL How Can We Help? 20220628_144231
Jeep Wrangler JL How Can We Help? 20220628_144211
Jeep Wrangler JL How Can We Help? 20220628_144235
Alabama
Thanks again!
- Benny
Thank you but it all worked out! The main piece was flawless and was ordered to replace the damage caused by the delivery truck driver scraping his feet getting in and out!
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
I can see what you mean and would imagine that the powder coated finish + steel construction of the tube door is thicker than a standard painted sheet metal door. I am glad they are taking care of the situation for you.
- Benny
Altitude2020
Canada
- Benny
Thank you. Hopefully someone figures out how they mount. I will still try and figure it out why they don't fit. I gave the part number to someone in the Gladiator forum, hopefully he will post how he got the clip to grab the tube door.
Rico1111
Rico
RI
Rico1111
Rico
RI
Thanks Benny:rock:
RAO
Ray
NC
2015 JKU Sahara; 2022 JL Rubicon; 2025 Sahara
Hi Benny,
Happy 4th!
im interested in ordering the 2.0l turbo water pump inlet tube, the gasket and the bolts to have as a spare, given the leak issue. It’s numbers 1 and 2. Gasket not shown but appears to have clips on it to hold in place. Thank you.
Jeep Wrangler JL How Can We Help? 1656766093929
EagleJL
Raleigh
2021 2dr Sarge Green Willys
UPS
Hi Benny, I'm looking for this Part that is sewn to the top of the back softop window. Also looking for the white inserts on either end. Thanks!
Jeep Wrangler JL How Can We Help? 20220619_152649
Trini
Cali
2022 Jeep Wrangler Sahara 4xe
Hi Benny,
I'm looking for the tube doors (rear kit only). I currently have the two front tube doors.
EDIT: This is the OEM Mopar rear tube doors that I'm requesting.
