Bubba33
- Chris
- Mar 30, 2018
- Saint Louis, MO
- 18 jeep wrangler Sahara JL
No spring compressor needed. Loosen the control arm bolts, unhook the sway bars, unhook the shocks, and then let the axle droop all the way down until the coil spring just falls right out. Reassemble in reverse order.
The rear is easier than the front. The hard part of the job wasn't actually installing the spacers. The hard part was dealing with the horrendous instructions, hardware that needed to be modified to work properly, and figuring out how to monkey that front passenger corner bump stop extension bolt and nut together.
The bump stops were easy. I didn't take the control arms loose.
