Frustrating A-pillar Wind Noise
NonHypenatedAmerican
NWFL
2018 Wrangler JLUS
I am at my wits end trying to stop the A pillar wind noise only on the drivers side. I had the noise before my cowl lights and just to be thurough I removed the drivers side light and the noise is there. I put the windshield down and put silicone on the windshield frame in between the welds and still have the noise. Put on a new door weatherstrip and still have the noise. Only other seal to replace is the cowl/windshield weatherstrip. As soon as I hit 30mph the noise starts up. Even worse in a headwind There is brick going through the air noise which is normal and now add annoying ass whistle noise. :mad: Atleast I have no water leaks anywhere.
On the positive side I put on Mopar lift control arms and my steering has a more positive feel with the Rubicon suspension I put on a few months ago.
gato
New England
2021 JLUR
I have this same issue. My Jeep is quiet otherwise. But the driver's A-pillar wind noise is just annoying as hell above 40MPH.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Try putting some blue painters tape over the little trim pieces at the bottom front corners of the door windows. That's a major source of the noise. If it goes away then all you need to do is pop them off witha trim tool and put a little bead of silicone or some 3m tape there to seal it from the wind.
