- Oct 7, 2019
- Metairie, LA
- Website
- www.oraclelights.com
- 2019 Jeep Wrangler JL
- Occupation
- Automotive LED Manufacturing
Are your stock bulbs lackluster? Ready for a big upgrade in illumination with easy installation and a smaller price tag? ORACLE Lighting offers a huge array of LED conversion kits for any vehicle! Below, we'll give you a quick overview so you can pick which will work the best for your needs.
4000+ Lumen Bulbs - Premium option with Philips Luxeon ZES chips
These new high-output LED Headlight bulbs create a 4,000+ Lm blanket of light for the driver to increase safety and nighttime visibility. Philips Luxeon ZES chips allow for the increased Lumen output while still drawing less than half the power of the factory headlight bulb. These smaller chips also have excellent heat dissipation characteristics, making them extremely reliable even in harsh environments.
The new internal driver components were designed by Samsung and offer excellent performance in a smaller package. The new adjustable heat sink makes fitment issues a thing of the past since it is removable to reverse install or mount outside the headlight back-cap for added adaptability. More illumination, increased reliability, and easier installationā¦ all for LESS than before!
V-Series Bulbs - D.O.T. Compliant option with SmartDriveā¢ Active Thermal Regulation
Looking for a bright, versatile, and easy to install LED Conversion Option? The new ORACLE Lighting V-Series packs a ton a features to make it not only user-friendly but also an amazing value for the features you get with this all-new design technology. This new all-in-one diecast body design mimics the look of the original factory halogen bulb. This allows for easy installation without any additional wiring or external drivers.
The V-Series bulbs feature our SmartDriveā¢ Active Thermal Regulation (ATR) temperature management. The integrated constant current linear LED driver inside the bulb uses a system called āthermal foldbackā to protect the LEDs and the bulb components.
S3 Bulbs - Budget-friendly option with industry-leading Luminous Efficacy
ORACLE Lighting S3 LED Conversion Bulbs Instantly provide 3200 Lumens of Crystal Clear 6000K light output. The electronic components of the S3 Headlight bulbs are housed in a sealed waterproof heat-sink design, eliminating the need for external drivers and cooling fans.
The CSP (Chip Scale Package) LED Chip Design features a small package size but high intensity volume per unit with less heat value resulting in industry-leading Luminous Efficacy (science talk for āBest Bang for your Buckā). This new low-profile design reduces common bulb fitment issues for an easy Plug & Play DIY installation.
